Question about Panasonic KX-P7100 Laser Printer
KX-P7305 (Duplex B/w ) Toner leakage onto printout edge
I Have cleaned out old toner as much as possible without dismanling
machine. Problem persists.
HELPplease
  • Lionroy Feb 18, 2008
    Awaiting message
  • Lionroy Feb 19, 2008
    Response did not address need to open up machine
  • 796 Answers
Hello sir
Posted on Feb 18, 2008
  • isaac johny
    isaac johny Feb 18, 2008
    Any image problems like this are electrostatic, and nothing to do with how much toner is left.
    Cleaning the drum is usually not a recommended thing ... the surface is easily damaged.
    Condensation on the drum can have a major effect. I've seen a
    photocopier producing black pages after being overnight in an unheated
    building. Some models of copiers have had a heater in the drum to
    fix that problem.
    There are various electrodes in the engine which are meant to be
    cleaned by the user from time to time. They usually have brightly
    colored handles on them.
My brothers printer 2170w has toner sprayed all over in printout
Three possibles for this.
1 A faulty cartridge dropping toner on the paper as it passes through the drum. - remove the toner cartridge and look for lots of loose toner in the drum.
2 The drum cylinder is dirty and needs to be cleaned with alcohol and a cotton ball. Toner can build up on the drum cylinder and also the cleaning brush inside the drum assembly. These would need to be cleaned - or replace the drum. And 3 progressively either or both of the above two may have lead to a build up of toner on the fuser at the back of the machine. In very bad cases the teflon type coating on the fuser may have peeled. If the fuser is dirty, it can be removed and cleaned. If it has become damaged - forget it, just buy a new machine.
May 19, 2014 | Brother HL 2140 Laser Printer
Toner is on edge of printout
clean the paper path and the drum first
Apr 16, 2013 | Brother MFC-9440CN Laser Printer
I have 3 to 4 months old canon Imagerunner 2420L Printer *** photostat without duplex or any network /scanning facility.The Printout coming very faded, if I print on the backside of the printout . Eve
hi my immage scanner ir2420 display says front left side is open /close but i close evry thing steel the same falts so may be power suply problem how can i get diyagram of power supply plz
Nov 05, 2012 | Office Equipment & Supplies
My printout is "missing" a couple of columns as
it is toner problem just change it.is it better if you install new toner.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Dirty Background on Printouts
The most likely problem is not with the drum unit but rather with the developer unit and there is a leakage current within the unit causing the 'ghosting' on the printed images.
I would suggest that you replace the developer unit within the system. It is quite possible that the waste toner blade is contaminated with debris from using non-OEM toner within the unit. Therefore leaving residual toner particles on the surface of the drum.
Try this solution and see if that corrects your problem. This solution can be applied to virtually any laser printer, copier or MFP device in the industry. The problem is nearly 99% of the time related to CHEAP toner cartridges that are refilled or refurbished and the company doing the work does NOT replace the cleaning blades within the units, and they use a generic polyester-resin toner that does not conform to manufacturer standards.
I worked as a Design Engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times in the industry. The price you save on using recycled cartridges ends up costing you more when you have to replace a developer or drum unit.
Hope this information helps you out.
Cheers,
Keith
Oct 22, 2008 | Sharp Office Equipment & Supplies
Panasonis KX-P7305 leaking toner
Sometimes what happens is the toner seeps onto and into places where only a vacuum and crevice tool and a brush will remove it.
It will get anywhere and everywhere, and wind up on the strenghtning flanges, it can be tricky and frustraiting to remove all of it.
Persistance and a smaller vacuum will most likely be what will allow you to resolve it.
Also take a look at your toner cartridge and be sure it is not leaking. There is no use going through all that, only to have it come right back.
Feb 19, 2008 | Panasonic KX-P7100 Laser Printer
Shadow On Printout
Here are the possibilities:
-drum blade is not cleaning well, take out toner look at the shiny cylinder ( drum) is there toner on it? change cartridge.
- transfer roller ( black roller on bottom of machine that comes in contact with drum) take lint free cloth and wipe may need to be changed,
Oct 11, 2007 | HP Color LaserJet 9500HDN Printer
Panasonic KX-P7100 Laser Printer Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
