Question about Olevia LT37HV 37 in. HD-Ready LCD Television
T.V. will not go on
Power light is on, but goes off when I try to turn set on and the T.V. will not go on and neither will the power light unless I unplug and replug it.
  • 2 more comments
  • mario777 Feb 19, 2008
    I have olevia tv the problem is don't turn on I check the fuse and is good
  • RUDEE Apr 25, 2008
    When I plug in the cord the light turs on, but the screen does not show any image just a fog like piture. Furthermore, the menu display nor any alike displays also don't show.
    I took the t.v. to a local repair shop and he said the t.v. can't be fix, that I need to purchase a new motherboard because a sort of chip can not be replace in which it is the problem.
    The motherboard cost around $300-$400.
    Should fix the problem by purchasing a new motherboard or buy a new t.v.?
  • psycho-drive Jun 01, 2008
  • Anonymous Jun 08, 2008
    i have olevia 237V 37in- only 3 months old- watching tv and just shut off- blue power light on but wont turn on ???? help
Mine is Olevia 237-s12
Posted on Jun 01, 2008
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
When i turn my tv on the red light goes to flashing green it comes on then immediatly it goes off but the light is on green... can you help
Tries tv unplug,replug it back about an hour later.The tv,now should reset itself back to factory setting.The tv should work now,not than the power supply board is dying,not giving the right voltage to the rest of the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | LG 42LG30 42 in. LCD HDTV
Sony HCD-BC150 As soon as I turn it on, it shuts
Change the audio amplifier IC are on short circuit and that´s the cause your device goes to protect mode
Aug 11, 2009 | Sony DAV-BC150 System
All lights stay on solid, cannot get lights to reset, and printer won't turn off unless unplugged. When plugged back in it goes to the same state. Printer cartridge holder doesn't move to the loading
sir try to put your printer to factory settigs by pressing the "start" & "cancel" button together & while holding these buttons together,try unplugging & replugging the printer power chord 4-5 times from the back panel of the printer....
Apr 26, 2009 | Office Equipment & Supplies
Olevia 237-s12
It sounds like a bad power supply board. I have one in stock if you need one from a working set that has a broken screen. I'll send all boards for 100 dollars plus freight if you are interested. All boards include Power supply coard, tuner and internal lighting boards. Call me if your interested.
Ed
NC Electronics
307-266-4675
Jun 02, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
Vizio on the fritz
yes it it is the sub part. It is the IC's that pop the way to prove this is to measure the voltage to this board Vs, VE, Vsus, and Va these voltages are listed on the panel. if any are low unplug the the connector from the power suppy reapply power and check the voltages again. if they return then it is the board that was unpluged. if not replug the connector and unplug the connector that goes to the Y main board and check again. be sure to remove power each time you unplug and replug the connectors.
Mar 16, 2008 | Televison & Video
Wii won't work after "incorrect memory card" was inserted.
you shouldnt need a memory card to save wii games it has 512mb internal memory.unless your trying to play gamecube games on it.the wiis security features are incredible if it cannot recognize a controller or memory card it will power down.make sure you are using a SD memory card because it will not accept anything else.it will power down for safty reasons.
Jul 14, 2007 | Nintendo Wii Console
Olevia LT37HV 37 in. HD-Ready LCD Television Logo
389 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
