Question about Goodman Heating & Cooling
I have a Goodman condensing unit that freezes up occasionally during low ambient weather (20 F). Model # ssz160361ac with matching new air handler. I have adjusted the defrost time from 90 to 30min. This I thought took care of it but it happen again when the temp dropped really low. When watching, it will go into defrost and clear the coil. But this last time the coil did not clear when I woke up this morning and the system was calling for heat but not running the heatpump.
    Scholar:
  • 185 Answers
It is not freezing up because of the temperature, but because of ice being formed in inside. Either by a blocked condensation duct, or snow due to previous storm.
Posted on Jan 31, 2010
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
Why is suction and discharge lines of Goodman WMC24-1A split ac system freezing up.?
Low on freon, dirty evap, dirty filter or maybe restricted at the metering device
Jul 20, 2014 | Goodman Heating & Cooling
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
Keeps freezing
low air flow or low on refrigerant.
Jul 24, 2013 | Goodman Heating & Cooling
My Goodman home air conditioner is freezing up during very warm weather. What is the correct high and low pressures for the Freon 22 during the running. I know it varys on outside temperature, so a chart...
The ideal pressures will be 68psi on suction and 225 psi on the liquid line.
If the pressures are close you should look for a blockage from dust in the evaporator coil,loose fitting air handler panels or a defective fan motor.
Jul 31, 2011 | Goodman Heating & Cooling
Hello, my HVAC is constantly freezing, even after freon is added. I was told that I have a leak in the coils and need to chance the air handler - the outside unit is about 10 years old - air handler about...
No you can not use a R-410 air handler with a R-22 condenser unit...the exspansion devices are different as the properties of the refrigerants are enough different that they are not interchangable...
Really your only choice is to replace the whole unit as it sounds like the exspansion valve or the orfice is partially clogged and it makes you constantly freeze up....
There are some things you could do to make it work at reduced capacity but it is way beyond what I could tell you through a computer...
heatman101
Sep 08, 2010 | Goodman CKL42AR42 Air Conditioner
My heatpump keeps running, but only drops temperature 1-2 degrees. I have a variable speed blower but I don't think that it is ramping up all the way. Air can be felt about 12-18 inches from the registers...
You have a low refrigerant charge. Your low reading which coresponds to the temp at the coil 49psi is about 20 degrees fr. It should be closer to 70 psi depending on the ambient temp indoors. The coil has to be above freezing I usually shoot for 38 to 40. your sub cooling needs to be at least ten. And if you cant feel the heat leaving throuhg the condenser fan it aint moving it.
Jun 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Compressor freezes up at night and some during day.
You are being ripped off. The ambient (outdoor) temperature at night is low and therefore proper condensing does not take place causing the refrigerant to pool in the condenser and starving the evaporator. This causes a lower temperature in the evaporator resulting in "freeze up" which is often mistaken for a loss of refrigerant.
The proper thing to be done is to block off the condenser air causing the high side pressure to rise until the eqivillant of 110*F condensing temperature.
You can also install a low ambient kit which will cycle the compressor off when the temperatures fall
Jun 07, 2009 | Weather King 12AJA4801AH Air Conditioner
Condensing unit continues to run after air handler is stopped. Problem is intermittent. Thermostat replaced. Suspect air handler relay. which one?
When this happens, most often you'll have a stuck contactor coil on the condenser. If you buy it , it should cost $20---to 15.00 and you can add if you turn off the power (240volts) and the furnace power!
Sep 09, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
124 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
