Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
While running my 22hp B&S engine just started reving up at extremely high rpm. does it have a governor control that broke or something
  • 105 Answers
Sure sounds like it!! a breakdown manual will answer that question best. good luck
Posted on Jan 31, 2010
Iv put a new desil fule pump on but it over reving do I need the timing dun
timing has nothing to to with engine rpm
governor control does
something was not assembled correctly so call in a diesel specialist to correct the fault
Jan 19, 2017 | Cars & Trucks
Briggs & Stratton Small Engine 110P02/0003-F1 start circuit
has nothing to do with start circuit. there is a spring that need to be bent at the metal arm that holds it to set your rpm up. or if you have a cable loosen it and adjust to correct rpm. do not over rev.
Jul 18, 2016 | Garden
How do I set governors on craftsman 22hp model 917.275970
governors on this engine are mechanical they are activated by a linkage that extends out side of crank case to a spring , if your rpm is not maintaining correctly id look at spring , if its malformed or broken heres part number of new one (691019) this is avail from sears parts
Jun 22, 2015 | Craftsman Garden
I have a Lincoln Ranger 8 with an Onan Engine. When started the engine runs at an EXTREME RPM. What causes this?
Check movement of the governor arm without it running. You should be able to move it by hand. If it is stuck, it could be the idle solenoid, or possibly something else more major.
Feb 26, 2015 | Lincoln Welding Tools
Wenling jennfeng generator governor not working, linkage ok, speed ran away while in use
that doesn't make sense , surely it has a governor how else can the carby rpm be governed , sounds to me like the internal governor thrust counter weight has come out of it's locking plates. if governor arm has been adjust wrong way or moved from it's original position this will happen .
Mar 28, 2014 | Electrical Supplies
Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Revised: I have a 1990 Ford F150 Its an automatic
THIS MODEL DID CAME WITH ELECTRONIC THROTTLE CONTROL TO DRIVE THE RPMS ACCORDING WITH THE SPEED OF THE VEHICLE,AND IF DOES THE SAME THING IN REVERSE HAVE TO VE SOMETHING RELATED WITH ONE OF THE CABLES OR MECHANISM TO DRIVE THE THROTTLE BECAUSE REVERSE IS DIRECT GEAR AND NOTHIG TO DO WITH SLIPERY CLUTCHS IN THE AUTOMATIC
Sep 24, 2009 | 1990 Ford F150
Extremely high idle speeds develped overnight
check idle speed control make your throttle valves not stuck.check for vacuum leak around the throttle body area look for broke gasket.
Apr 13, 2009 | 1987 Ford Ranger
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
578 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
