Question about Compaq Presario R3000 Notebook
Hey I want to capture dvd ? , what is the s video jack for?
How do I capture from DVD and what all can I do with the svideo jack?
    Problem Solver:
  • 9 Answers
To capture a DVD you can download a dvd ripping program. There are a lot of them out there, so just do a google search to find one that suits your needs. An S video jack is used to output the video to another display, such as a tv. To use it, connect it to the tv and then hit the monitor button on the keyboard.
Posted on Feb 21, 2008
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How to convert hi8 tape to cd or dvd
your camcorder has only A / V out.. it does not have USB or Firewire as some later models have ... so you need a Video Capture Device ... those are available as a card that is installed inside your computer or as an external USB device .. some of these devices use only SVIDEO which this camera does not have .. so you need a capture card that will do composit NTSC video ... most of the older ones do that .. then you might need adapters if its connectors dont match your camera .. the capture card or device usually comes with simple video editing software that can burn to a CD or DVD .. or you could use more elaborate software like Nero (nero 9 is the latest i think) .. there are many other editing programs available ..
here is a review of "video capture devices".....
http://www.aboutvideoediting.com/hardware/top10.shtml
some video cards already have "video in" connector .. its often SVIDEO .. so that wont help .. but some have analog (composit) inputs that you can use ..
here is such a USB video capture device that will work with your camera .. ........
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3428849&sku=A03-7134
Jan 20, 2010 | Sony Handycam CCD-TRV57 Camcorder
I HAVE A ZENITH TELEVISION AND I CANNOT HOOK MY DVD/VCR COMBO TO IT. THERE IS NO PLACE TO PUT THE CABLE. MY TELEVISION HAS THE ANTENNA/CABLE PLUG AND THE YELLOW,WHITE,AND RED OUTLETS ON.
your TV has composit video in but your DVD/VCR only has Component video and Svideo outputs ..those are not compatable with your tv .. if you look more closely you might find an SVideo input on your tv .. its flat and not as easy to see as the normal jacks .. if your tv does have SVideo then all you need is an SVideo cable (plus the two sound cables) ... i could check on what you have if you give the TV model number .. othwise you have to have something to convert your SVideo to composit video .. there is a cable that does that .. you can check with radio shack .. if they do have such a cable then one end would plug into the svideo of the dvd/vcr . the other end would plug into the yellow jack on your tv .. hook up sound and it should work ok ..
here is such a cable on the internet ..
http://www.cablestogo.com/product.asp?cat_id=2012&sku=27964#tab=review
or google "svideo to composite" to see lots of options
Nov 22, 2009 | Sylvania DV220SL8 DVD Player/VCR
Kworld TV88x audio problem
How are you plugging it in to the capture card? Some cards are video only, You have to buy a card that does video and audio. Most have an adapter that connects to svideo, and rca. I would go with a usb unit. That is what I use. Thanks
Dec 27, 2008 | Computers & Internet
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Sound
Svideo is video only
Mar 16, 2008 | Sony Hi8 CCD-TRV138 Camcorder
No video output from rca jack or svideo
The problem is with the p.scan button. It seems if its pressed the video goes off. You need to keep it pushed until you see a message for "progressive scan".
Dec 08, 2007 | Samsung DVDR120 DVD Recorder
No image
Yes they are surface mounted componets and without a schematic and an ocilliscope I think it will be near impossible to find the trouble if the problem is an IC. If you have access to a scope try tracing the video signal from the RCA output jacks and see where you see it come up. Good Luck
Mar 26, 2007 | Koss KS4110 DVD Player
Compaq Presario R3000 Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
