Question about Onkyo TX-DS777
My Onkyo TX-DS777 won't come out of standby mode. The red power light is still on but the receiver won't turn on otherwise. Help!
  • 2 more comments
  • jakecraven Jan 31, 2010
    Ok. Strangely, the problem started earlier this week when the receiver would consistently cut on/off by itself. I would turn it off and leave it alone for awhile and eventually it would work alright again. I was just able to turn it back on. A friend mentioned something about an internal code that could be programmed from the receiver itself. Ever heard of anything like this?
    The first solution didn't work.
    My Onkyo TX-DS777 won't come off of standby mode. I've tried unplugging it for an hour, checking all wires for frays, removing the casing and dusting out the inside of the receiver. Nothing seems to work. Help!
  • jakecraven Feb 01, 2010
    Thanks man. I've taken the casing off and looked for anything out of the ordinary but everything looks ok. However, I don't have much electrical experience so my eye is pretty untrained. Any particular area I should be looking?
  • 1,068 Answers
This is an indication of an internal fault weather it be with in the power supply or output stage of amp that won't be know until serviced. but this is what need to be done . take it in for service and or check the fuses in side the unit in the power supply. not usally that simple but you will never know until it get opened up and looked at. good luck and ask any more question you have.
Posted on Jan 31, 2010
  • michael schultz
    michael schultz Feb 01, 2010
    yes the heat sink (aluminum block) in side has a few transistors on it. see if there is any burns or black char if so the problem is in the amp. if not it may still be there but could also be i the power supply.
  • 2,335 Answers
Start by unplugging the unit from the power outlet for several minutes to reset the brain inside. While it is unplugged, check all your speaker wires for loose filaments of copper that could be shorting out your amplifier causing a protection fault.
I hope that helps.
Onkyo TX NR515 .. when in standby mode .. light is not coming on .. everything works fine .. i must have pressed something by mistake but cant work it out what ... on the display panel in standby mode...
If Zones are turned on or, if a mobile device connected to the Front Input is charging (MHL), the HYBRID STANDBY indicator won't light. See the TX NR515 owner's manual at http://filedepot.onkyousa.com/Files/own_manuals/TX-NR515_English.pdf for more info.
Feb 19, 2015 | Onkyo TX-NR515 AV Receiver
Can i connect an ipod to my Onkyo tx-ds777?
You should be able to do it with the right adapter cable.
Jul 21, 2014 | Onkyo TX-DS777
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
Power problem
Danny,
It may only need to be reset, unplug it for a min. plug it back in and try it.
Check your owners manual some will tell you how to reset them.
Also check for a jammed switch, press every switch one by one if one doesn't move that is the problem, you can possibly unjam it with a small screwdriver.
But it could need servicing.
Jan 23, 2009 | Onkyo TX-DS777
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Onkyo TX-DS777 Problem
man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress soy_robertog01@hotmail.com
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Jun 22, 2008 | Onkyo TX-DS777
Tx-ds777 onkyo receiver codes
Hi Firewall
What remote do you currently have that you need the codes for?
regards
Graeme
Jan 18, 2008 | Onkyo TX-DS777
Onkyo receiver TX-DS777
You have a bad amplifier left or right whichever pops if both sides pops then it both amps
Dec 25, 2007 | Onkyo TX-DS777
Tx-ds777
Same thing happened to our TX-DS777.
Took it to a locate electronic comany and they told us it was the
DSP board gone bad. Est 425.00 to 450.00 to fix.
Aug 16, 2007 | Onkyo TX-DS777
Power light on, unit will not turn on with push button
When power was intermittant, were there any other discrepencies or audible power deprivation to the speakers? Your problem has many possibilites from fuses to major amplifier problems to common power supply failures. Being intermittant then dead may still be a simple fix, but not without some physical intervention of test gear. Sorry, Jaszy
May 30, 2007 | Onkyo TX-DS777
Onkyo TX-DS777 Logo
635 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
