Question about Car Audio & Video
Hello any body there to help me - Car Audio & Video
  • 2,335 Answers
There are many people online here to help you. Please provide as much information regarding your problem as you can, including make and model of what you are troubleshooting. This allows us to provide the most accurate information possible.
Posted on Jan 31, 2010
Hi, have a 62 Buick skylark 2 door convertable with a paint code no# FB 4509 and unde NN1 paint company in australia cannot match this code to get me the paint required.Can you help with this please.
Hello there Annie,
Well I think I know WHY nobody can match the paint. The code you have presented is the body assembly number. The 'FB' refers to the body being build in Flint Michigan, then I believe the numbers afterwards are the assembly number.
Regardless of all that, there should be a body plate about the size of a credit card (I take it this is where you came up with the number to begin with).
Just below where it says 'Body' it should say 'Paint'. Just to the right of that is the actual paint code.
BUICK Body Plate Identification
AND, here's the paint codes for 1962;
1962 Color Codes Buick Paint Cross Reference
Hope this helps.
Jan 18, 2017 | Buick Cars & Trucks
1987 jeep comanche will stay runnning only when spraying carburetor cleaner in carburetor or when you pump throttle rapidly
Hello
It sounds like a glogged fuel filter or throttle body problem. Disconnect gas line at carb get a small jar or can to catch gas, hold gas line in jar and have someone crank engine, If you have good gas flow to carb then Its a throtle body problem, (Throtle body and carb are same thing just in case you did not know)could be electrical or mechanical problem at throttle body, Its usually electrical, fuel flow meter. Hope this helps
Oct 23, 2012 | 1987 Jeep Comanche
Body Control Module
Hello, guys. Perhaps this article may be able to help you. It talks about body control module. Hope it could help you.
Sep 12, 2012 | 2005 Ford Escape
96 monte carlo idle fluctuates when standing still. Also lights go dim when idle drops. changed both O2 sensors, battery, tensioner belt, and altenator. Mechanic thinks its the choke sensor but knows...
Hello and welcome. sounds like the throttle body may be just dirty. remove hose from air cleaner to the throttle body. clean out the throttle body bore and around the throttle body with some throttle body cleaner. then retest and see if the problem is repaired
Dec 20, 2011 | 2001 Chevrolet Monte Carlo
2002 Trailblazer is stalling when the A/C is turned on. Just had the valve gaskets on the coils replaced along with the intake gasket and a tuneup. Never stalled before getting it fixed. Any help would be...
Hello, sounds like a dirty throttle body. try cleaning out the throttle body bore with some throttle body cleaner. remove the air box from top of the engine assembly. there are two 10 mm bolts that hold the box in place.clean out the throttle body real well using cleaner and a shop rag
Aug 21, 2011 | Chevrolet TrailBlazer Cars & Trucks
Hello any body slove my problem Privacy lock code of samsung gt s3310 i froget it
hello any body slove my problem
Nov 17, 2010 | Samsung Lands Phones
My start button giving problem can any body please help me .....
below I post you a schema of your pin connectors. 6 & 8 is the power switch, and 5&7 is the reset switch.
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | Mercury P4VM800M7 Motherboard
Hi I need new brake disk front and rear for my DR650 RSE 94. Is it the same brake disks like other tipe of DR650 and year's 92-95 models or it is different? I looked on Ebay and so just one tipe. So need...
Hello,the only difference between a rse,se,re,so forth is some with enduro body,kick start ,enduro body, electric start, Tour body,kick,tour body ,elec. and so on and on,other words just the body plastic and starter system is all...
Apr 06, 2010 | 1994 Suzuki DR 650 RS-E
When I weighed myself 4 times in a row today it read 4 different weights. Is the battery wearing out? What do you think.
hello. Definitely change the battery. Also make sure the scale is on a hard surface, not carpet.
please rate my answer as helpful. thank you.
Feb 23, 2010 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
NEED TO REPLACE MY THROTTLE POSITION SENSOR BUT CAN'T FIND IT ON MY TRUCK
Hello. The Throttle Position Sensor (TPS) is on the outside of the throttle body assembly. It's beside the throttle plate inside the throttle body. Once you remove the air cleaner from the throttle body you will see what I am talking about. I hope this helps, please don't hesitate to ask any other questions about this.
Feb 09, 2010 | 2004 Cadillac Escalade Ext
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
