Question about Boating
What is the low end jets setting 1&1/2 turns or 2 full turns on c
What is the low end jets setting 1&1/2 turns from dead bottom or 2 full turns from dead bottom?? for all three carbs on a 60 hp yamaha 2000 yr model??
  • 2,926 Answers
1.5 turns out is a good place to start, then you will tune the engine from there.
Posted on Jan 31, 2010
Factory carb settings for this saw? Could ssome one help me with this ?
What kind of saw is it???
on average low jet is about 1 1/2 turn counterclockwise out after bottoming out the jet slightly
high jet about 1 turn counterclockwise after bottoming jet out clockwise
hope this helps getting your saw going
Dec 04, 2015 | Garden
Repair manual
Hi Robert:
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Bud
Oct 03, 2013 | whipper snipper stihl fs 38
Chain saw will not idle
L 1 full turn
H 3/4 of a turn
depends on the make of carb. some carbs on Husqvarna tools like blowers and strimmers are 2 1/4 turn on both H & L
Dec 26, 2012 | Husqvarna Garden
Honda mower HRU173PU carby screws adjustment
Hi Paul
Please take time to rate me
Bud
Oct 27, 2012 | Honda Garden
How many turns out is the factory setting on the high and low needles
Hi stanw71
Bud
Oct 13, 2012 | Husqvarna 128LD 17" Gas Trimmer
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Car settings stihl 026 with wt 194 carb?
Hi Alan Cowart
Sep 09, 2012 | Stihl 026 Ms260 024 Ms240 Original Walbro...
Wt 194 settings
Hi
I have a 1995 kawasaki ts jet ski it runs but goes really slow will not hit high end. i just got this jet ski it looks like the carb and lower end of motor is new. i did find some water in carb and cleand...
If the carburetor was properly cleaned including the teeter-totter float needle then you may just have accidentally changed the setting screws. Try setting the the high end and low end adjustment screws the standard settings are: Low speed screw: 3/4 turns out (+ or - 1/4 turn for fine tuning) high speed screw: 1 1/4 turns out (+ or - 1/4 turn for fine tuning) If the previous owner rebuilt the whole machine but could not figure out why the boat would not rev out, the next thing to do is remove the water box and and split the halves. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch27834 If a mouse nest has been built in the exhaust system the extra back pressure could be the problem. If the exhaust coupler has broken rubber tubes, has come apart, or has not been put together correctly that might also be the cause of the problem. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch29444
Aug 08, 2011 | kawasaki Full Suspension Mountain Bike Men
Sitting for while pulled carbys apart washed cleaned reset mix screws 2 half turns, up size exhaust with reverse condes on now, back firing on deconpression.
sounds like your running lean. start with your main jet/needle adj. make sure the bike is pulling hard the WHOLE way to red. after you have that you can work the pilot jet and air fuel screw. Now do you have your air fuel screws 2 half turns out from dead bottom make it one full turn, or 2 full turns and one half from dead bottom. if you have not installed a jet kit there is where you need to start. and please dont forget to sync your carbs when your done.
If you can give me the jet sizes, needle settings and air/fuel screw setting. and we will get this worked out
M.Woodring
May 11, 2011 | 1993 Ducati Monster 900
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
