Question about Microwave Ovens
The On button keeps blinking and it will not allow me to blend.
  • 2,335 Answers
Please provide make and model information for the appliance you are troubleshooting. The more information you provide, the more accurate our solutions can be.
Posted on Jan 31, 2010
How do I stop the dashes on my kenmore microwave oven to stop blinking
some models blink so they keep time that way but if it doesn't change you haven't finished settings
Jan 02, 2015 | Kenmore 1.6 cu. ft. Countertop Microwave -...
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
LED On light keeps blinking and blender does not blend.
make sure the power cord is firmly connected to the unit. Also check to make sure the container is properly seated in the base.
Mar 05, 2011 | Microwave Ovens
Coffee maker DCC-2000 will not keep coffee hot,have change the auto off time no effect.
Well the procedure to set the auto button off would be as follows. First set to 0 so it shut off as soon as it started brewing. Once the switch is turned to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. If this does not keep the coffee warm then most likely you have a heating element down and will need to replace it. Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 03, 2010 | Cuisinart Microwave Ovens
The "clean" light keeps blinking. It will not allow me to start another cycle or to cancel/drain.
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
I have often found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
If you have any questions, please let me know. I hope this helps you solve your problem.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons.
Dec 09, 2009 | Microwave Ovens
Model jvm1430wd002 keypad is locked
This is a built in safety feature called "Child Lock-Out" that allows you to lock or unlock the control panel to keep small children from manipulating the controls.
To lock/unlock, simply press and hold the CLEAR OFF button for 3 seconds.
If you have questions, please let me know. I hope this helps you.
Aug 15, 2009 | Microwave Ovens
Unable to start my microwave. keep on blinking after plug in
It sounds like your keypad or controller may have failed. This is a problem with the control panel assembly, which we repair nationwide for $39.95 in most cases. Full details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 12, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Powers up but does not START cooking = Displays colon after you press START
I would check your onwer's manual for any other specific reset instructions. Generally it reset by unplugging it from the wall for a few minutes. Does the microwave require you to set the time and date before it will work? Are all the keys on the keypad working or do they seem to? If not, you may have a bad, damp, or corroded keypad or control circuit board. I can follow up more on these if it seems like your problem. Please met me know what you find.
Dec 30, 2006 | Panasonic NN-T694SF Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
