Question about Sony Cyber-shot DSC-H2 Digital Camera
E 91 01 THE FLASH DOESNT WORK AND IT GIVES THIS ERROR CODE
Just go in "menu", "set up 1", "initialize", and select "ok". With that you will reestart your camera. I already did it twice in my DSC-H2 and the flash came back to work. Goo Luck!!
Posted on Feb 27, 2010
  • 3,083 Answers
Look on google, and you will read about the error code and what it means. Probably a bad capacitor for the flash, but if you quickly turn off the flash in the menu, you can use the camera. If you want to use the flash, you will have to replace the capacitor or have it replaced.
Posted on Feb 15, 2010
  • terminatorlx Aug 25, 2011
    I have had the 91:01 error message for about two years. The reset options worked to remove the error message, but the flash was still inoperable. I read here that this could be a capacitor problem. Using instructions I found here:http://www.ifixit.com/Teardown/Sony-Cybe... I was able to isolate the high voltage chip that controls the charging the capacitor. One of the ribbon cables had simply come out of its harness. I reinserted it, put the sumbitch back together and it works perfectly! I have never, ever had any experience with electronics, much less dismantling their intricate parts. If you got some guts try it out. Be careful with the capacitor, it is capable of holding a lot of charge!
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Optiarc dvd rw ad-7700h
If the drive is faulty, the driver will give error code 32 which means it failed to load.
Check out flea bay for a replacement drive.
Nov 25, 2013 | Dell Inspiron Computers & Internet
D4 light is flashing and check engine light is on. doesnt want to start
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help link provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
http://alltypesofpartsreplacing.blogspot.com/2012/12/check-engine-lightengine-warning-light.html
These will help.
Thanks.
Dec 10, 2012 | 1992 Honda Accord
Daikin FTY45EV1A split system wont turn on, has flashing timer light on. I turn the unit on and off by the remote, still doesn't work. What does the flashing timer light mean?
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Jun 14, 2011 | Heating & Cooling
I have a canon pixma 258 (all in one printer). cartridges are full. The problem is it doesnt print or scan any document. If a print command is given, it gives an error ' printer is in use. An error has...
Observe how the power and error lights are flashing. Or count the times they are blinking and in what sequence. This is more accurate than error codes. Repost with this info so i can help you further.
May 10, 2011 | Canon PIXMA MP240 All-In-One InkJet...
The flash pops up but doesnt work. than gives me a busy signal than gives me the 99 warning. it was dropped a short distance from my hands. just want to know what i can do myself. if anything
This error is usually assocociated with a dirty lens mount.. rub both lens mount terminals and camera terminals with a pencil eraser making sure nothing gets inside the works. and reassemble.
Other reports indicate it can also be the battery terminals.. do the same thing.
regarding the flash.. if the lens mounts are dirty ( or misaligned requiring repair) the flash will not flash.
Please rate my help++++Thanks for using FIXYA
Nov 19, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
No output. power button flashing red
Its giving you a trouble code you will have to find out what that is. Try youtube. How to repair your xbox.
Nov 06, 2009 | Microsoft Xbox 360 Console
Flashing prnds with 17090 error code
punch this code into google search and research the answers that show similar symptoms
Sep 13, 2009 | 2003 Audi A4 Cabriolet
Battery ran down.now radio/clock don't work. flashes Error.can this be reset?
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me.
good luck
May 29, 2009 | 2007 Honda Accord Sedan
Printer does'nt work
You printer is giving you an error code with its flashing coloyr lights. I would consult canons website and write down the exact colours it is flashing as this is a specific error code. Most likely it is a paper jam error or reading error. Before you contact them i would try resetting the printer by powering down, unplugging all cables and cord, replugging and turning on and retry print jobs. If no luck go to plan B, webesite, and find error code. I am sorry i have no deatils for this printer to give you the error code myself.
Aug 31, 2007 | Canon BubbleJet i560 InkJet Printer
Sony Cyber-shot DSC-H2 Digital Camera Logo
381 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
