Question about HP Compaq FS7600 17" CRT Monitor
What is the corect resolution for this moniter
It's native resolution is 1280 x 1024 / 60.0 Hz.
Posted on Jan 31, 2010
Hello the problem I have is when I turn off my moniter while the computer is still on the resolution settings have changed when I turn it back on,I don't know why this happens is there a driver that needs...
well it depends, do you know how to check the drivers for the display in Windows? which version of Windows do you have? I would suggest to start looking at the resolution, see if the drivers are up to date for the video card, also I suggest hiring a professional if you are not sure.
Dec 16, 2017 | Acer P205H Widescreen LCD Monitor
When i install vista and upgrade video driver moniter unable to display resolution pixo a700 moniter
press f8 and keep pressing untill menu appears tjen highlight on enable vga mode and press enter your problem will be solved if you want to see high resolution then insert an AGP card into an AGP slot then you can see high resolution use 8X AGP card for better result
Apr 29, 2010 | Neso Technology Pixo A700 17 in. Flat...
I just purchased a acer moniter ...I plugged it in and the picture looks a little distorted (my grand daughter says I am not use to the new flat screen) on the moniter was a film cover that said make sure...
If your on XP you can right click on the empty desktop and go to properties, Under the settings tab you will find options for screen resolutions. If your on Vista or 7 you right click on empty desktop space and go to screen resolution, There again you will easily find your settings for your screen resolution. Click apply and then click OK after that lay back and enjoy your screens clarity.
Apr 25, 2010 | Acer X183HB Monitor
Image on monitor is stretched
if you have recently added the moniter to your pc then go to microsoft windows updates and run the custom updates and under hardware on the right there should be a download drive stating the name of your moniter and download it,,,unless you have not set the resolution in the control panel after pressing start and go to moniter display to adjust the slider to the right setting,good luck
Nov 10, 2009 | Computers & Internet
Input not supported
screen resolution probably the problem if you have another moniter like a crt(which can support higher resolution) change it to the lowest level resoultion and then put in you lcd moniter and see if it works and if it does change the resolution to a comfortable level for you
May 22, 2009 | AOC A15X221 15 in. LCD Television
My moniter wont display anything
Your moniter resolution is greater than its compitable resolution.You have to start it on its safe mode.First unplug your coputer cable then restart it then you have to select Start with Safe Mode.If it doesn't work you have to format your PC.
May 17, 2009 | Computers & Internet
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
Picture is too big on computer moniter
try to change the Display settings with a higher resolution, example 1024 x 768. It's under control panel - Display and Settings Tab.
Apr 01, 2009 | Dell 2350-DHB7R21 PC Desktop
No display on moniter but cpu is running
change the RAM(RANDOM ACCESS MEMORY) of your pc.
Dec 12, 2007 | Intel Motherboard
HP Compaq FS7600 17" CRT Monitor Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
