Question about Zanussi ZWF1430W Front Load Washer
Smell of burning
Hi there
I have the above dishwasher DA6141.
Yesterday when using the washer, there was a smell of burning, when i opened the door the right hand side of the element was glowing Red Hot.
There was water in the washer at the time.
Can you tell me if this is an element fault and it needs replacing?
Many thanks
Richard
Our Zanussi DW915 Dishwasher started to have a burning smell around 6 weeks ago which seemed to be coming for the element as the smell was very strong when the door is opened. There also seems to be a lot of heat being generated which you can feel as soon as the door is opened.
The Dishwasher was still finishing its cycle until recently and now what happens is the main eccentric fuse switch is tripping around half way through the wash.
My first thoughts are that there may be an issue with a thermostat because of the heat that is being generated and released when the door is opened. Could this be the issue and if it is then could we also have damaged the element as it has gone a little black around the area where the element enters/exits the inside of the dishwasher.
Any help would be greatly appreciated
Stephen
  • stephen177 Feb 24, 2008
    Thanks very much for responding Trylo. I have ordered the element which should arrive on Tuesday and I have sent an e-mail off to Zanussi asking them for details of the stat that controls the temp. Also checked for any dry joints and all seems fine.
    Thanks again.
The Element is shorting out, tripping the rcd. replace the element, thermostat,and any cut outs that are in the element cricuit. The element should not be glowing which means the stat is shot and the safety cutout for the element is shot also, while you`re at it check out the circuit board for dry joints, discoloured resisters, bulging capacitors etc.
This is VERY dangerous situation, as the machine has the potential to set your house alight and burn it down!. If you continue to use it in it`s current condition you may well damage other componants - rendering the machine B.E.R - Beyond Economical Repair. I will will advise You to never to leave this machine unattended, do not go out after turning it on and have a nice afternoon in the park etc, you may well come home to a pile of ashes!
Posted on Feb 23, 2008
I have the zanuusi ZWF1437w washing machine. Water will not go into it when switched on. The hose is not kinked and the water is switched on.I have tried all the programmes and it goes onto the drain cycle on all of them.
Posted on Apr 08, 2011
I am a fully qualified Zanussi engineer.
This is definitely a fault with the pressure switch.
Posted on Jun 29, 2009
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Won't start . power is applied to washer, but no lights are on.
99% its the control board that locate in the door.
open the screw of the door see if there is any fuse or burn smell..
Jan 21, 2010 | Kenmore Dishwashers
A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Nov 17, 2009 | Whirlpool 24 in. GU980SCG Built-in...
My dishwasher smells like an electrical fire!
the smoke could be plactic silverware that fell on the heating element,or a plastic lid. this is not an easy fix.sometimes it is more cost effective to replace a unit than to repair it.good luck with yuor project.
Aug 04, 2009 | Maytag JetClean II MDB8551 Built-in...
Buit in dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
iio
Jul 08, 2008 | Zanussi 24 in. DA6141 Built-in Dishwasher
Smelled like burning plastic
Ron, is this a dishwasher or clothes washer? If a dishwasher, check the wire nuts in the junction box. If there isn't a melted wire nut from a loose connection. Then you have to pull the outer door panel, then you can pull the control panel assy. This will require a t20 torx bit.
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Zanussi ZWF1430W Front Load Washer Logo
291 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
