My moffat dryer is not heating seems like heating coil is gone,like to know how to replace
    Brigadier General:
  • 3,513 Answers
Please find the step by step instruction to replace the heating coil in your dryer.
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Thanks
Posted on Jan 31, 2010
Lg dryer dlex3360v runs but does not heat
The reason why it runs with no heat is because the heater coil has just gone out you need to replace your heater coil in your dryer and then it'll work
Feb 07, 2018 | LG Dryers
I have a Maytag dryer model DG412 that recently stopped heating. I replaced the igniter and it worked for a few minutes then stopped again. When I removed the igniter it broke into pieces.
Usually if it heats for few minutes then doesn't relight one of the coils has gone bad. They come as a pair as you know somake sure you replace both. You have done everything right so far... You do have bad coils though.
Dec 09, 2016 | Maytag Dryers
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Moffat cloth dryer overheat
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Sep 07, 2014 | Dryers
We have an LGR8648 gas dryer. When you start the dryer, it heats up just fine. At some point (after 15-20 minutes, it seems) the burner goes out and never comes back on. Is there a thermal sensor or...
The most common cause for your problem is the gas valve coils. There are 2 and should be replaced in pairs. Over time, they will fire when you first start the dryer but fail to fire again once in mid cycle. A link for a typical set of coils is listed below:
Whirlpool Gas Valve Coil Set of 2
Jul 24, 2011 | Whirlpool LGR8648 Gas Dryer
My kenmore series dryer does not heat. the timer
the heater element has two parts to the heat coil if one of the coils breaks it will not get hot enough to heat the load all the way to set of the sensor to stop . it seems like you need to replace your heat element . if you want to know how to take it apart i have a couple of posts that tell how or reply back the coil costs about 89 dollars you can get one pre strung for around double the cost
Feb 25, 2010 | Kenmore 63942 Dryer
Heating but taking a long time for clothes to dry
most of the time if it takes to long to dry it is your wall vent hole or dryer vent hole that has gotten clogged,clean both and you should be ok,let me know how you do.-mike
Mar 18, 2009 | Kenmore Dryers
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
