Question about HP Photosmart C6180 All-In-One InkJet Printer
I have HP C6180 and all it does when I turn it on is have a load on the screen and it seems like it just keeps reseting itself
    Guru:
  • 731 Answers
The printer is having a hard time to self initialize, which requires a reset. Please try the below steps to fix the issue.
Step 1: Power Drain
  • Turn the Printer OFF
  • Disconnect the USB and power cable from the back of the printer.
  • Remove the power cable from the wall outlet.
  • Press and hold the ON/OFF button for 30 seconds. (Discharges the static current off the capacitors).
  • Connect the Power cable to wall outlet and to the printer.
  • Turn the printer ON.
If this didn't resolved, try below step 2.
STEP 2: - NVM RESET.
  • Remove the ink cartridges from the printer, close the cartridge doors.
  • Wait for 30 seconds and disconnect the power cable from the back of printer, while the printer is ON.
  • Press and Hold "OK" and "Cancel" key, while holding them, insert the power cable behind and keep holding them for 10 seconds and then release.
  • If the printer goes OFF, push ON button to turn it on.
  • Then insert the cartridges when the display prompts and check the printer.
Thanks & Regards
Rizwan
Posted on Jan 31, 2010
C6180 constantly resetting itself
http://www.fixya.com/support/t7081394-c8180_continues_reboot
Jan 06, 2012 | HP Photosmart C6180 All-In-One InkJet...
Green light flashes , but the printer will not startup disply only shows hp logo
Issue seems to be with the hardware of printer.
You can try following steps to reset it to "factory default settings"
1- Unplug the power cord from back of printer when printer is turned on
2- Wait for 30 seconds.
3- Press and hold # and 6 on printer while plugging the power cord
4- Printer may shut off itself
5- Press power button to turn it on
6- Select country and language
7- It will clean and align itself. May take 7-9 minutes
8- It will print an alignment page, place the alignment page on scanner glass and press ok
Wish for all success..
Dec 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
My printer keeps turning itself on and off, code OXL19a0022, is ther a reset procedure? C6180
My C6180 had the same turning on and off problem. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other printers .acca299.jpg
Dec 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C6180 repeatly keeps turning on and off, but it never makes it to main screen. The HP loading continues to load and then auto shuts down (i do notice a flash of orange screen) I tried to...
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other printers . acca299.jpg
Sep 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
Keeps turning itself on and off.
my C6180 would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers 0f91d7c.jpg
Nov 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 keeps rebooting itself
Hold the "#" and "6" key down as it reboots. This is the equiv to a cold reset.
Sep 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 boot - init loop / power on-off loop
The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180
unplug the printer and then plug it back in. turn it on and Hold the 6 and # button until the printer shuts off, this should do a hard reset
Apr 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP c6280 Won't load ink cartridges
Per HP:
Hold “print photos” button and “red-eye removal” buttons together, release
ø Then press the “red-eye removal” button, release
ø Then press the “print photos” button, release
ø Then press “red-eye removal, release
ø Scroll to “resets menu”, click ok to select
ø Scroll to “Options” semi-full reset, ok
The printer then powers off and wait a couple of minutes. I believe the printer turns back on (or maybe the user needs to power back on after a few minutes). The refills then work.
Mar 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
