Question about HP Compaq nc6000 Notebook
Starting problem hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Posted on Feb 05, 2010
Hp nc6000 when pushing on , it will on orange light and off againg
1,check power supply.
2,check battery.
3,check the fan is trying to run.if its not it may need cleaning.
4,over heating can stop it from starting.
Jun 27, 2014 | HP Compaq nc6000 Notebook
Laptop HP compaq NC6000 does not boot, fan spins led start up and go off
Hi,Thanks for using fixya,
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 23, 2011 | HP Compaq nc6000 Notebook
My HP nc6000 wont start when I press power button. Fan starts for a few seconds an then the orange led turns on, after that everythig turns off. AC an the battery is ok. Any idea? Thak you.
Hi,these particular brand of Hp series is very problematic,try checking the Ram out,its usually underneath the keyboard,so if you have two installed try using one at a time to boot system,if problem persist have an I.T Technician look at it.
Dec 31, 2010 | HP Compaq nc6000 Notebook
Laptop starts to fire up then shuts down...had it up and running to put Windows XP on it no problem. Has new CPU, battery,, Keyboard 512MB RAM...Can anyone help?
Hi, I posted few days ago with similar problem. I have nc6000 and problem was that I couldn`t thrun it on, the fan starts and orange light was turning on, than it all stops. I received possible solution from BlackMamba, but I did it before and it lasts for a few months. Now, I read about same problem on few blogs and finaly I decide to disassemle it an to find that famous max1987. I found it reflow with heat fan for soldering and guess what...? It works. I am not ready to celebrate yet, but I think that soldering max1987 is the real solution for that problem. Thaks. Bye.
Dec 08, 2010 | HP Compaq nc6000 Notebook
My hp compaq nc 6000 wouldnt start up, i press the power button on the laptop and can see the blue light and the orange ligth of wireless connection and power turns on can hear the fan starting but in 3...
In this case it is an windows problem you need to reformat your notebook. So that the windows have fresh copy. If the same things happen the problem is the RAM you need to replace the RAM.
Aug 10, 2010 | HP Compaq nc6000 Notebook
Hi,My HP Compaq nc6000 just developed a problem of not coming on. I have checked the battery and its okay. I have blown its internal parts and it remained off. It only indicates the orange light for some...
try taking the battery out completely and see if the laptop runs of the main power from the outlet, if so then the battery may have a bad cell in it and would need to be replaced.
Primary Batteries
6-cell Lithium-Ion (4.4Ah) – standard
8-cell Lithium-Ion (4.4Ah) – optional
Power SupplyExternal 65 watt AC adapter
from looks of it the battery has gone bad
http://www.laptopbatterystore.com/product/2151/compaq-business-notebook-nc6000-batteries?utm_source=GoogleProducts&utm_medium=CSE&utm_campaign=Compaq/HP&utm_term=HP18S6-Compaq-Business-Notebook-NC6000-Battery
Aug 20, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 wont start up
Hi there.
This could be a problem with the system memory.
Take the battery out and the AC power, turn the laptop over and look for a panel with screws on it, unscrew the panel and you should see something like this >>>>>>>>>
Unclip the memory by pushing the little lugs outwards and the memory should pop up ready to be taken out, get a clean dry paintbrush and clean the memory and the slots.
If you have more than one stick of memory just put one of them back and try booting the laptop up.
If one works try the other and see how you get on.
Post back for any additional help
Good luck and thanks for using FixYa!!
May 26, 2009 | HP Compaq nc6000 Notebook
HP compaq nc6000 Start up problems
cpu is getting over heated because the fan cooling it is slow or not working well or stopped . go into setup , see the cpu temperature, and fan speed , if normal , neglect the above cause.
change ram , use any other working ram .
battery may not be fully charged , or old battery.
battery faulty (current leakage or less working voltage or less current storage capacity,
use mains supply , if lap top is ok on mains supply then charging section or battery is faulty.
Aug 15, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
986 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
