Question about Dell M992 19" CRT Monitor
Out of frequency
Dell m992 monitor is going to out of frequency :
tell me some ideas,
i m waiting for your reply
SOON.
that's my ID
abdulghaffarabro@hotmail.com
  • Robert Swanson
    Robert Swanson May 11, 2010
    Hiya! What version of windows are you using, and was your monitor working on the same pc recently?
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
SHEMATIK DIAGRAM
http://elektrotanya.com/?q=showresult&megnev=Dell&megnev2=M992% 20 & Category = & kat2 = all
Jun 12, 2010 | Dell M992 19" CRT Monitor
My Dell M992 monitor screen is blurry and there are squiggly lines running through it. The color is perfect. I even changed the resolution with no luck. Is it time for a new one or can it be fixed? I...
Check the cable going from the pc to the monitor and ensure the connections are secure. You also may want to try moving the cable away from any other power cords if possible.
If this does not help then most likely it is time for a new one.
Nov 12, 2009 | Dell M992 Monitor
No power
OK disassemble the monitor and visually check for bad components or cold solder here is a couple of examples.3bf0ae5.gifcold solder12cd393.jpeg bad capacitor
Jul 05, 2009 | Dell M992 Monitor
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
Power but no display
does the screen show no signal, it could be from thedigital button setting on the monitor try to adjust the setting,
2.check the video card ,you can test it on another system,test the monitor on another systems thats working fine if it continues may be its frm the systems or the monitor tube is bad if your using the correct resolution
May 26, 2008 | Dell M992 19" CRT Monitor
Dell m992 screen problems
If you notice, when you see the windows start screen, its usually "big and dopey". Thats because the video drivers aren't being used yet. If it is blanking out right after you see that screen (with the scrolling bar), my guess is it's a corrupt / bad video driver.
Was any other hardware added recently?
Jan 10, 2008 | Dell M992 19" CRT Monitor
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
Severe gradient issues / problems with darker grays
So your sure when you go into the monitor settings, and color, it is set to like 9300k or something? It probably isn't the monitor, because the video games you said display just fine.
Dec 19, 2006 | Dell M992 19" CRT Monitor
Dell M992 19" CRT Monitor Logo
67 people viewed this question
Alun Cox
