Question about Graco Quattro Tour Kentshire Stroller
I have one of your pushchairs that needs servicing and some bits fixing do you know where i can have this done as soon as poss as i use it alot thankyou
  • 29 Answers
Hi there you can have your pushchair serviced at www.buggypitstop.co.uk
Posted on Feb 10, 2010
Service engine soon light
The service engine soon could be an indicator that you need to have minor maintenance done in the near future. I had a Grand Am that the service engine light would turn on when I was getting close to needing an oil change. You might check your owners manual for an exact reason as to why it turns on.
Aug 06, 2012 | 2006 Pontiac Grand Prix
My nissan maxima leaks oil where is it comming from?
if your car has alot,saying that im talkin 200.000 plus miles on it poss could be that sensor o ring,they very rarley fail unless lots of miles on drive train.without knowing how bad the leak is or any other pertinant info, like any recent service done? how long has it been leaking? does it only leak while running?while running under a load? or just sitting? all off the above? my guess would be valvecover gasket,front cam seal,oil fill cap, cyl head gasket? with just the info at hand to go on it could be any of these things pretty much in that order,if you can do a little more investigative work to answere some of the questions i asked you should get a verry accurate answere and poss things to address along with whatever maintenence needed to remedy the leak .
Jul 05, 2012 | 1995 Nissan Maxima
My service engine soon light is on. i had my oil changed recently but it was on before i had that done. i have to get my state inspection and need it off. how do i reset it?
the service engine soon light is not for the oil or anything like it, it is warning u that the electronic engine control system has a fault present, there are about 200 poss reasons so you will need to get the system teasted, Kragen and Autozone both do this test for free, just ask for a OBD 2 fault code test, don't listen to the suggestions of what is wrong, they are not trained in this and often you end up buying parts that don't fix the problem, seek a Ford dealer out or other trained electronic engine control tech for assistance in fixing the problem, u may also post the codes on this site, I suggest u use live chat for the best and most accurate answer.
Mar 29, 2010 | 2002 Ford Explorer
2002 ford expedition "service engine soon" light keeps coming on. I've had the O2 sensor replaced three times in the past month, now the next day or two after the sensor replacement the light comes back...
get a new mechanic, need to check for vac. leaks, poss needs tune up. alot O2 codes i have gotten have been created by vacuum leak or warn out plugs, rarely have i had to replace a O2 sensor.
Oct 14, 2009 | 2002 Ford Expedition
SERVICE ENGINE SOON LIGHT ON FRO oLDSMOBILE 2002
without knowing the trouble code that is set in memory anytime the check engine light comes on there is no way to know the problem or if there is a fix under any type of recall, there are over 200 fault codes poss in this system, have it tested for which code turned the light on.
Sep 28, 2009 | 2002 Oldsmobile Intrigue
I can't fix on the two large wheels onto my Hauck pushchair
Hi just bought the same and spent over 2 hours trying to fix the back wheels on as they just kept falling off. Just discovered the diagram is wrong, insert cap c the other way round, it takes a bit of pushing but once on the black small cap d snaps shut keeping the wheels on. Hope this helps
Sep 04, 2009 | Hauck Infinity Umbrella Stroller
Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
May 18, 2009 | Quinny Buzz Jogger
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Graco Quattro Tour Kentshire Stroller Logo
Top Graco Baby Gear Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
