Question about Draper Silhouette/Series V Motorized Screen - 31.75 x 56.5" - M1300 Projector Screen
I don't know how to connect the wires.
I am trying to do an install
  • 2,335 Answers
I can help source an installation manual for your Draper Motorized screen, if you can provide full model information. All my screen displays is "Draper Silhouette/Series V Motorized Screen - 31....." and then the model number is cut off.
Posted on Jan 31, 2010
Missing .INF file on install
I'm trying to connect to our network printer (Konica Minolta) but with no success....I'm then getting an error saying that the "*.INF file is needed"....I don't know what to do further.
May 11, 2012 | Office Equipment & Supplies
Magic chef wiring connect
Hello Kym....I know you may want to try this yourself...BUT...an electric oven is a high voltage device..usually 220 volts...and if you are not equipped to directly connect this....PLEASE have this done by a professional....Don't try this...This is not a novice...do it yourself project...I hope this was helpful.......PEACE....
Feb 09, 2012 | Magic Chef 9522 Electric Double Oven
My shredder jammed so I took the top off of unit in order to clean. When I pulled the top back it pulled all of the wires loose. Being inexperienced I should have made a "diagram" of where the...
I'm afraid i cannot help you to tell you where each specific wire goes first because the wire colors mean nothing without sources and destinations but i can tell you this:Each wire has an elastic memory so that the shape it had before you opened it should remain the same. This means that you can deduce where each wire goes. Also you should have an electrician do the connections as there could be some voltage/amperage issues.
Jan 01, 2012 | Office Equipment & Supplies
Electrical conntection for Chandelier Tried to send problem twice before, but don't know if you recvd it. My problem is the wiring for install. outlet box has 2/blk/2wht/1red....fixture has...
use the same as when you took it down, white is neutral, red is power from switch, green is ground, look at wiring for new chandelier instructions should tell you what goes where, if al else fails get an electrician to wire for you
Sep 06, 2011 | Home
I don't know which wire goes where on my car I have a 1994 Honda del sol and I don't know hot to connect the wires from the radio to the connector in my car
I recommend you purchase a wiring harness. You can order one specific to your vehicle. This will take the guess work out of what wire is which. Hope this helps.
Aug 15, 2011 | Car Audio & Video
Im trying to install this product in my 2000 saville but the colors dont match and there are a whole bunch more wires left on the caddies harness
If you don't know what you're doing, you're much better off taking it to a shop. You can do untold damage to the car, even setting off the air bag, if you don't know what to do in there, particularly if you don't have the right tools.
Jun 25, 2011 | Kenwood KDC-MP242
We are trying to install a HoneyWell programmable thermostat (model RTH6350) and the colors do not match up. We have an orange wire, blue wire and white wire without a connection. It says to wrap the O,...
T-stat wiring is commonly connected with the following color codes:
On a straight heat and cool system:
White = W on T-Stat
Yellow = Y on T-stat
Green = G on T-stat
Red = R on T-stat
On heat pump systems:
Blue = W2 on T-stat
There is no guarantee that your system is wired using this system so you will need to look in the furnace and see where the wires are connected to. You will have another set, probably 2 wires, going to your outside A/C unit. They are typically red and white but could be any color as long as they are hooked up to the same connections. I.E. blue on R at t-stat and to R on furnace would be OK, it just makes it harder to service the unit if you don't know what wire is for what.
Just check your furnace connections and connect the same wires to your t-stat no matter their colors.
Jun 14, 2011 | Honeywell Heating & Cooling
2007 TOYOTA SOLARA DASH LIGHTS SHUT OFF WHEN CAR IS IN DRIVE .
Don,t know why this problem happens....but to get the dash working again remove the dash cluster. There are two white plugs in back of the cluster. In the larger of the two which is dead center on top of the cluster, cut the wire which is in pin #2. It will either be a black/white for the convertibles or a black for all others. It will be next to a white/red wire. Just tape off each end then tape up the harness. No connections are made. Don' t know why this works but it does. Problem seems to happen when remote starts are installed.
Jun 29, 2010 | 2007 Toyota Solara
Wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
Draper Silhouette/Series V Motorized Screen - 31.75 x 56.5" - M1300 Projector Screen Logo
Top Draper Televison & Video Experts
Electro Med Services...
Are you a Draper Televison and Video Expert? Answer questions, earn points and help others
