Question about Aprilaire 700 Humidifier
My Aprilaire humidifier is leaking water. What causes this and how do I fix it?
  • Aprilaire Master
  • 3,291 Answers
Hi check inside might need cleaning check connetions is drain pipe clear could be blocked filter
Posted on Feb 02, 2010
5 Suggested Answers
  • 9 Answers
SOURCE: The Aprilaire is leaking around the casing attached to furnace
How old is the filter? Filters should be replaced every year. If its a new filter check to make sure the little hose is inside the hole at the tom of the filter.
Posted on Jan 19, 2009
SOURCE: Leaking humidifier
Check for an obstructed drain line.
Posted on Mar 04, 2008
SOURCE: water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Posted on Mar 04, 2009
  • 232 Answers
SOURCE: Testing a Aprilaire Humidifier 600 Controller
if it works in the test mode then it should be okay but you can get a humidity gauge from radio shack and set in the house to see how high or low its is. the humidifier is only going to give a max of 45% humidity
Posted on Dec 31, 2009
My aprilaire mod. 300 seems to release an excess amount of water through the drain tube. it waste a lot of water.is there a fix?
This is typical especially if there is not much air flow across the humidifier. Make sure the fan is running in the humidiifier and the core does not need to be replaced. Sometimes I have had to turn the water valve back a little to cause less water to go through to conserve that wasted water.
Apr 09, 2011 | Aprilaire 700 Humidifier
My Aprilaire 600 is dripping from the front toward the bottom... Can I fix it myself or do I need my maintenance guy?
Hello, check to make sure that the drain line is not blocked, this could cause the water to back up in the humidifier and leak, also make sure the water panel is clean and free of any mineral deposits.
Feb 09, 2011 | Aprilaire 600 Humidifier
The water basin that receives and pumps out the excess water on my Aprilaire 600 humidifier runs incessantly, even when very little waters in in teh basin? Is there an easy fix? thank you
If you are referring to a condensate pump then the float might be stuck and causing the pump to run continuously. The best thing to do is turn off power to the pump and clean it out and make sure the float is free and not stuck.
Jan 21, 2011 | Aprilaire 600 Humidifier
Water leaking
Hi, you can use this as a guide...
aprilairehumidifierparts.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Hope it helps.
Thanks for using fixya...
Nov 14, 2010 | Aprilaire 700 Humidifier
Nov 27, 2009 | Aprilaire 600 Humidifier
Water is leaking out of it
purchase a maintenance kit from aprilaire. this needs to be done annually.
http://estore.aprilaire.com/catalog/humidifiers/model-700-series-parts/232
Oct 13, 2009 | Aprilaire 700 Humidifier
Water keeps running into humidifier even furnance blower is not
Feb 19, 2009 | Aprilaire 550 Humidifier
Leaking humidifier
Feb 28, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
414 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
