Question about Panasonic PT-56LCZ70 56" HDTV
When you turn the unit on it just flashes green until a certain time and it will cycle off and flash two times red continuosly. after several tries and around thirty minutes it will finally light off.
  • Panasonic Master
  • 19,396 Answers
Hi.
The green light is the ordinary led light, the TV still does not turn on because there is a fault.
The red flashing light is not a diagnostic code, but means that the fault had been detected, and the TV protection circuit had started.
When this happen, the protection circuit will shut down all PSU volts apart low +5V to keep the flashing led on. The TV will not respond to control when in this mode.
All you can do is checking all connections, and leaving the TV disconnected from power for about fifteen minutes.
If that does not fix the problem, then there is an internal fault.
In that case contact manufacturer at the number listed on the manual.
You can follow the instructions on this article: Why my TV does not start up and remains in.
Most common fault causing this problem is a defective PSU, but the TV must be disassembled and tested to find out.
If the fault light went off by itself and the TV started normally, then the problem may have been a temporary fault caused by electrostatic charges accumulating on PSU capacitors, that is quite common, particularly after a power surge.
If the problem comes back, that means that there is a component that is starting to fail.
Commonly PSU electrolyitic capacitor, or Convergence failure can cause the problem developing in this way.
Regards.
Posted on Jan 31, 2010
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Will not turn on after charging
Sounds like it's time for new batteries.
Jul 18, 2009 | Jet 3 Ultra Power Chair
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Jan 07, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Standby light blinks 6 times
It is fuse issue again. Go to this website and you should have solution or ask for one:
http://www.avsforum.com/avs-vb/showthread.php?t=507602
Dec 18, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Panasonic PT-56LCZ70 56" HDTV Logo
292 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
