Question about Canon PIXMA MP130 All-In-One InkJet Printer
How do i open the printer to get to the waste
My printer canon pixma mp 130 doesn´t print and only gives me an ¨ink waste reservoir almost full¨ message. how do i open the printer to get to the waste reservoir pads?
    President:
  • 2,306 Answers
Getting to the pads won't help, they are under the print engine and cover the whole bottom of the printer. The cost for a new set is around $10.00, but after changing you need to get to the service mode to reset the counter, and only Canon shops can do that.
Posted on Jan 31, 2010
Testimonial: "thanks for a quick reply to my question."
Need to find the waste ink absorber in a pixma mp 130/110
There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jun 26, 2011 | Canon Office Equipment & Supplies
How can i reset waste in basket for mp 130 series.
Do you mean reset the waste ink pad? You can find several methods here:
http://www.fixyourownprinter.com/forums/printer/43878
Apr 08, 2011 | Canon PIXMA iP90 Mobile Printer
Pixma mp 130 Message waste tank absorber is almost full. It wont print
Take the printer to a qualified printer technician.
He/she will empty the waste-container,
and "reset" the electronics inside the printer,
to tell the printer that the waste-ink container has been emptied.
Oct 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Pixma MP/130 Waste ink absorber almost full. How do I fix it please?
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Apr 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My Canon Pixma MP 170 tells methe waste ink absorber is full...
It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error. The new part is around $10.00 only.
Jul 01, 2009 | Office Equipment & Supplies
My canon mp 150 has a warning ink refill cartridge
After so many prints the printer gives you this warning because it is possible that the waste ink pads (that collect any spilt ink in the bottom of the printer) are full. You have two options. You can either reset the waste ink counter and the printer will run but might get some ink leakage if it has had a lot of use or replace the pad and reset the counter.
A waste ink kit for this printer is Canon part number QY5-0149-000. A quick search on the will get you the part for about £5. Too fit it you will need to take the printer apart but that is easy with a service manual from here: http://www.tradebit.com/filedetail.php/4589462-canon-pixma-mp150-printer-service-manual The manual will also tell you how to reset the waste counter.
Hope that helps.
Nov 07, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber is almost full
Try this:
Resetting overflow error code for Printer Canon Pixma MP110
  1. Turn on the printer.
  2. Click Menu, and then Scan, Copy and Scan again. All - entered the service mode.
  3. Select Counter
  4. Click Copy - everything. Waste dropped to zero.
  5. Turn off the printer POWER button.
Good luck
Oct 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
Aug 01, 2008 | Canon Office Equipment & Supplies
Canon mp 130 printer waste ink
hi
am AJAY FROM INDIA
off the printer and open upside cover,see 'the waste ink absorber if there any spunge pull that
and empty the waste ink from sponge or waste ink absorber
ok
again cloused the upside cover
ok
Jan 03, 2008 | Office Equipment & Supplies
Canon PIXMA MP130 All-In-One InkJet Printer Logo
140 people viewed this question
old marine
old marine
