Question about Car Audio & Video
Its a 250 watt power acoustic amp the inline fuse is 70 amps the speakers are two 12 inch kicker comps so if i just lower the in line fuse it should work any recommendations on the size of the fuse
  • kingjames_19 Jan 31, 2010
    okay thank you but the wiring kit is a schoche wiring kit it has a black rca and a clear one which one goes to the red hook up and the white and on the speaker wiring to the amp do i wire each speaker to each slot on the amp the pos left and then the neg left like that keep them seperate or combine them like both positives and negatives its hard to explain
    One One
    sub sub
    Should they be wired like this its the best i can do or can you show me a better diagram
  • 2,335 Answers
70 amps is a very large fuse for a 250W amplifier.
Watts are Amps multiplied by Volts, so you can work backwards and get to a much smaller fuse value.
250W / 14.4V = 17A.
If your kickers are wired to run mono at 2 ohms instead of 4 ohms, then your amp may be putting out up to 500W instead of 250W, in which case you will blow a 20A fuse and need to run a 40A.
I hope that helps.
Posted on Jan 31, 2010
I have a lanzar vibe pro VBP251 2200 watts and two 12" kicker comp subs. What do I set the amp on
You need to figure out what ohm capacity is of the amp and the speakers. It then comes down to wiring.
Mar 02, 2015 | Kicker Car Audio & Video
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
What's the best way to wire a 12 inch kicker CVR
Ok, first you need to have at least ten gauge wire cause the amp needs agility of juice. Next you want to find a good ground to frame of the car (if its wrong you'll hear road noise through speaker.) Next look on the fire wall and find the terminal that has other wire coming to it (one from positive to the amplifier on battery the rest out top other you want to put an inline fuse to amp.and have ground write other side of the cart than the power. run write to amp then to your speaker I believe I made it is simple for you as possible good luck
Dec 07, 2011 | Kicker Car Audio & Video
Is two comp 12's with a 1200 watts nitro amp a
The 1200w rated for the amp is usually an absolute maximum output, the rated output is more likely about a quarter of this figure (300w) I think for the subs you are looking at, you would be better off with a more powerful amp
Hope this helps
May 06, 2011 | Kicker Car Audio & Video
I have a 12 kicker sub and a 600 wt power acoustic
there is a volume on the amp try that and the settings on your deck allow you to adjust your subs
Jan 15, 2010 | Kicker Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Bass not Very deep
250 watts rms seems a little low for a 12 inch woofer, a 500 or higher will likely fix your problem. Specific model numbers and the type of enclosure you have will allow a more specific answer.
Mar 17, 2009 | Car Audio & Video
Mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
Sep 26, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
