Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Runs out of hot water very quickly - Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
  • 105 Answers
One of the heating elements is burned out. check them with an ohm meter to see what one, very easy. DON'T DO THIS JOB IF YOU DON'T KNOW PROCEDURE!!!!!!! this heater is run by 220 volts, the kind that'll kill ya if your not careful. if you have to call plumber, you can give him the tank info, tell him it is a bad element, and he'll come do it for you. be safe!
Posted on Jan 31, 2010
Runs out of hot water fast
Test elements, and if elements are good, replace both thermostats.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Rheem does not post service manuals.
If this is 3-phase balanced water heater, then information above is altered.
Otherwise parts are generic and testing steps are same
Mar 26, 2013 | Rheem ELD80 Commercial Electric Water...
Running out of hot water
Turn the heat higher on the hot water. So you will use less water. There is normally a knob to turn the water higher.
Mar 28, 2012 | General Electric Water Heaters
Very hot water then it kicks off and I have to frequently reset
Even though the water is very hot do you run out quickly? If so the problem is the 'dip tube' if not it is most likely the upper thermostat.
May 07, 2010 | RELIANCE ELECTRIC WATER HEATER
My gas hot water heater runs out of hot water very quickly. what should I do .It is 10 years old and just started to do this.
Check the gas valve first, it may have inadvertantly been turned down. The knob should be red and have settings on it. If it hasn't been turned down, it sounds like it's nearing its end. Good luck
Dec 26, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Run out of hot water quick
There is a thin plastic fill pipe in every storage water heater. Its where the cold water is fed in from the top... it travels the entire height to the bottom, as hot water sits on top. There is likely a crack in that tube. It is replaceable, but it is a very big nuisance depending on the size of your tank.
If thats not it, its potentially a weak high limit. Which shuts the tank heat off and never lets the tank reach it optimal temperature.
Dec 19, 2009 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Drain valve leaking, water too hot
If this is an electric unit, you have to remove the cover to locate the thermostat. It sounds like the thermostat is malfunctioning. The excessive hot water can cause a unit to leak due to the expansion of the unit due to the overly hot water. Make sure that your breaker is off before you remove the covers to expose the thermostat.
Mar 21, 2009 | Water Heaters
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
117 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
