Question about Maytag Atlantis MAV8551 Top Load Washer
I have a Maytag Atlantis top load washer.Model #MAV 8601 A WW. Serial # 25274759 GG. It is leaking water under the tub. I can't tell exactly where it is leaking from. Could it be possible there is a seal under the plastic tub, or the spin bearing is worn. Need help is solving this problem. It leaks more when the tub goes into the spin cycle. The machine is approx. 7 yrs old. Is it worth fixing? I took it apart a week ago and when I did there were 3 screws loose on the bottom above the transmission. I tighen all three hoping this would solve the problem. It did not. Need explanation and guidance on how to disassemble and put back together. PS. I am determined to fix this problem on a very tight budget.
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Large leak during wash cycle---Maytag - model LAT9520AAE top load washer
hey guys i guess this is not a uncommon problem. I have a commercial washer about 4 years old that get moderate service at a rental of mine and it is leaking from the tub as well. I hope to fix the problem because the new machines are very expensive.
Posted on Sep 08, 2008
huuum
  • 750 Answers
SOURCE: maytag atlantis washer mav-31
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Is t your washer cleaning the clothes and operating fine other than the noise?
If so do not spend any money on it unless it breaks or does not operate!
"If its not broken do not fix it!"
I know this is not the what you wan to hear!
I have a telephone number of the consumer affairs of for maytag that's hard to find!
If you call them thay will demand that thier servicers find and remedy the problem or swap it out for you!.
Even if it is past warranty.
I'm not at work for another couple of hours.
When I get there I'll give you the 800 number for Whirlpool (They now own Maytag) Consumer affairs and you can cal Monday!
I do this frequently for my customers!
Everyone knows,
"It's easyier to keep the customers you have than find new ones"
But no matter what happens,you have no need to pay the repair persons child's college tuition!
You have your own needs!.
How much did you spend on this machine even though it did wash and perform?
Noise is not broken or failure.
I had a Maytag Neptune that did this for 6 years and I fixed 2 other problem unrelated .
Then on the third break down I dumped it in the trash and bought myself a Speed Queen Commercial
washer that will last me 25 years for half the price of the $999.00 Maytag Neptune.
When I complained to my father about the noises in our family car he used to tell me,
turn on the radio.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
  • 10865 Answers
SOURCE: Lint in the wash water/clothes
If you have a regular tub/agitator machine you can fill 1/2 with water, add two cups of white vinegar & allow it to agitate but not empty. Give the machine a break to 'soak', then agitate again. Allow the vinegar-water to sit in the tub between rounds. Do this for the whole day (on weekend?) to give the machine a good cleaning. Often soaking in vinegar will loosen trapped debris so it can go down the drain. It will clean the machine very well even if it does not stop your lint problem. Sounds like there must be some part in the machine that got clogged w/ lint or that there is a hidden lint trap. Read the instruction booklet or try to contact the manufacturer via toll free phone or internet for troubleshooting on the problem. Good Luck!
Posted on May 18, 2009
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
May 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water built up in Maytag Washer Model MAV-17
I would check the water valves or the water lines. If the water valve is leaking, the water could be running out and following down the cabinet then in to the tub, or the water valve water line that leads right in to the tub there for leaving a water build up.
Mar 01, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
