Question about Whirlpool Washing Machines
Clicking grinding sound and water will not pump out
  • 234 Answers
Most likely it is your drive coupling that has broke; it is a common problem. You need to remove the shell (housing) and then disconnect the pump from the motor. Also, it may be the pump that has ceased-up and will not turn (therefore the click sound as the motor shaft turns but the pump does not. If the coupling is not bad, this is best time to replace coupling (it is on the other side of the motor) and will cost $10 for the part. The pump it usually not repairable and for $30+ buy a new one. Goodluck, Macgivor
Posted on Jan 31, 2010
My Emerson Portable Ice Maker started makeing a loud grinding sound when pumping water -why?
Probably the bearing in the pump is shot depending on how old it is try getting it covered under warranty
Oct 29, 2012 | Emerson Im90 Portable Ice Maker
Tip
Danby Designer counter top Dishwasher tyrouble with pumping sounds
I donot remember the model number.
when it pumps water i am getting a grinding/ clicking from it more like a chattering sound.
is the pumping going out on it? How do i fix or where can i get a new pump for it?
got it in 2001 and the troubles i had with it was a pluged sprayer lines I blow it out every other week beside that no trouble with it
on Sep 20, 2008 | Dandy Designs 22 in. SDW399W Free-standing...
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
Water won't drain from washing machine
could be the bearing on your drum
empty the water out and rotate the drum by hand
if it is grinding it will be the bearing
Jun 26, 2010 | Frigidaire ATF6000ES Front Load Washer
Grinding noise from passenger side engine
The water pump bearings could be going out and they will make a grinding noise.The water pump doesn't always leak when the bearings are going out.
Sep 01, 2009 | 2002 Dodge Neon
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
Water remains in Whirpool Gold Quiet Partner dishwasher
sounds like an issue with the drain pump, disconnecting the drain hose fromm the trap and run the unit, pointing the disconnected drain hose into a bucket. You should get a fairly strong stream of water until most of the unit has drained, if not you either have a blockage or ,with the grinding sound, a bad pump.
Mar 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water pump
if there are no leaks, then will be a grinding sound
Dec 31, 2008 | 1992 Honda Accord
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
