Question about Toshiba Wireless Broadband Gateway WBG-1200A (PA3175E-1ETC) Bridge/Router
I lost my WBG1200 manual and I don't remember the management IP address of the router. (luckily I still remember the log in and password) :)
  • 4 Answers
Can't figure out the ssid number on my router
Just log into your router if you need to know it's IP address. Go to the command prompt type ipconfig /all then look for the Gateway IP address input that into your web browser and then hit enter. Go to the Network Settings page and you will see you SSID and password.
If you can't remember your password reset your router back to it's factory settings by holding the reset button for about 5 seconds. For your model/brand of router the default IP address is 192.168.2.1 The default password is "admin" Once you are connected to your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be your phone number for example 3109876543.
Sep 07, 2011 | Microsoft Broadband Networking MN-500...
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I want to configure my router through web,but i ca not connect at 192.168.0.1 web address..
The default IP for the DIR-300 is 192.168.0.1. First, make sure you're entering "http://192.168.0.1" in your browser's address bar. In some browsers, if you try entering just the numbers, it won't work.
If you can't access the setup page at all, that address may have been changed. If this is the case, or you can't log in because you don't remember the username and password, you should reset the router which will restore the factory defaults.Press the recessed rear-panel reset button and hold it in for 10 seconds. Release it and the router will restart. The defualt IP (192.168.0.1) and username and password (both admin) will be restored.
Aug 16, 2011 | D-Link DIR-300 Wireless Router
I'm trying to sign into my Netgear Router to reset my password, because I do not remember it and to set-up a secure connection. However whenever I type in http://routerlogin.net, All I get is information...
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
  • All NETGEAR devices
Related articles:
Mar 26, 2011 | NetGear WGR614 Wireless Router
How can I find router I P address & password
Well it depends what ip address you are looking for - if you are looking for the local ip address all you have to do go is go to the command line and type in "ipconfig" without the quotes. What you are looking for is the gateway address.
If you are looking for the ip address the rest of the world sees it will be a little more tricky. The first thing you are going to want to do is log in to your router. You can do this by opening your web browser and in the address bar typing the local ip address of you router. (It should be 192.168.0.1)
You will be prompted with a log in box. The default username is admin and the default password is password. If you cannot log in using these credentials and do not remember if you have changed the password all you have to do is get a small pointy object (pen, paperclip, pin etc). Look on the back of your router for a small hole that says reset on it and push it in for 30 seconds. This will reset it to factory default settings - if you are wirelessly connected to your router you will have to reconnect to the network it will be called netgear most likely. You can then log in to your router.
Once logged into your router click on the "Maintenance" heading on the main screen then select "System Status"
Your IP address will be listed under the "Internet Port" heading.
Feb 23, 2011 | NetGear WGR614 Wireless Router
How do i change a password
If you don't have the current password, you will have to press the reset button located next to the power connector port. This will reset it back to factory default settings. The you can access it with your browser:
To access the Web-based management utility:
1 Open your Web browser and enter the IP address of the router into the
Location (for Netscape) or Address (for Internet Explorer) field, then press
Enter. The default IP address of the router is 192.168.0.1
For example, type 192.168.0.1
After the connection is established, the logon screen opens.
2 To log in as an administrator, enter the user name of admin and leave the
password field blank (default), then click OK. The Web management Home
screen opens.
You can download the user manual at:
http://www.retrevo.com/support/Dynex-DX-E401-Routers-manual/id/8352ag821/t/2/
Jan 15, 2011 | Dynex DX-E401 Router
How do I find the passkey for my router....I am trying to get my wireless printer to work and it id asking for my passkey and I don't remember any passkey?
usually the passkey will be found in the bottom of router, named as wep key...
you can log in to the router interface by typing the ip address of your router in any web browser, and you can find what is the password...
the ip address of linksys router will be 192.168.1.1
it will never change unless u changed the ip address of your router manually...
Aug 11, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Hot to reset the seting to default
You can reset your Netgear router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Get help for recover your lost wireless router password >>
May 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Lost signal between pc and i phone.
You have to find the router's IP address and log into the router. It would be something like 172.0.0.x. Since you forgot the router password, your going to have to press the reset button on the router itself to reset the router to factory settings. Check the user manual if you don't know where the reset button is. After that, your going to have to reset the password on the router. The usual default router username and password are "user" for username and "password" for the password. Make sure you make a more secure username and password for the router log in and router wireless security. If you need more help, write me back.
Jan 10, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I use the Remote Management feature on my router?
Remote Management allows the device to be configured through the WAN (Wide Area Network) port from the Internet using a web browser. Step 1 Log into the web based configuration of the router by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Tools tab and click the Admin button. Step 3 Select the Enabled button to enable Remote Management. In the IP Address field type in the public IP address you wish to manage the router. Note: If you don´t know the IP address or wish to allow more than one IP address to manage the router then put an asterisk (*) in the IP Address field. You cannot enter an IP range. Step 4 By default the port used to Remote Manage the router is set to 8080. Change the port number by selecting the down arrow next to the Port Number drop down menu. Step 5 Click on Apply and then click Continue to save the changes. To Remote Manage the router you will need to type in the Public IP Address of the router in your web browser along with the Port Number (separated by a colon) you selected in Step 4.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Toshiba Wireless Broadband Gateway WBG-1200A (PA3175E-1ETC) Bridge/Router Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
