Question about Goodman GMS90703BXA Heater
Ice accumulating at base of cple60-1c. The blower fan squeals when it attempts to turn and judging by the oil residue on the fan blades i would say the bearings are dry.
Heat turns to cool after five minutes
Posted on Jan 31, 2010
Ice is collecting on the fan in the freezer causing whirring sound.
Reduce thermostat setting point by point till no ice accumulation on fan.
Oct 01, 2017 | General Electric GSH25JFX Side by Side...
Think theres mildow or mold in unit from last year, how can i clean unit out
First, pull-out your a/c unit. Open the electrical control and remove the wiring connections of your fan motor and the compressor. Separate the electrical control and make sure you have the wiring diagram for termination. Unscrew all panels to remove the fan motor, blower, and fan blade from the unit base. You have to move the evaporator farther but be careful with the pipes. After removing the panels, fan motor, fan, and blower wash the coils with water using pressurized water. Spray coil cleaner to remove excess dirt from the coils and wait until all dirt come out. make sure the chemical is not too strong to eat the aluminum fins. Wash and rinse thoroughly the coils to remove any chemicals left in the unit.Clean the panels, fan, blower, and motor.Oil bush type motor.Then assemble fixing the panels, blower, motor, fan blade panel, and fan blade. Screw all parts and rewire the unit.
Aug 31, 2011 | Haier hwr10xc6 Air Conditioner
Almost no air comes from the ac vents but fan is on high. This happens on auto and also on econ.
The 1992 was prior to Buick putting cabin air filters in so there is not a possibility it is clogged. So more than likely your blower motor is going bad or your fan control switch is bad. Does this problem occur with heating as well as AC? Does it change if you switch between blowing on floor, face, window(defrost) If it doesnt change based on location of blow and type of air temp then I would start by turning fan on high and placing head (ear ) against dash in center of console area. Have someone turn fan knob from low to high with engine OFF...After goign from low to high and back a few times you can see if the blower motor is responding to signal from switch. Listen for a whine, squeal, rattle, or humm. A whine or Humm would indicate a bad blower motor... Squeal or rattle a bad squirrel cage/fan blower blades. If you hear no noise and no perceivable change in blower speed/noise then its possible your switch is bad. Unfortunately the only way to definitely diagnose either is to pull the switch from dash and use multimeter to test for voltage change and for blower motor to pull dash. There is a digital control unit for your car as well. Although rare sometimes the wires on this can loosen or it can go bad. But since you didnt state teh fan wasnt working at all and you are getting cool air, that woudl be teh last thing to check
Jun 06, 2010 | 1992 Buick Park Avenue
Fan blade does not immediately spin when turned on; loud
The motor bearings need machine (like sewing machine oil).
Try a quick spray of WD40 or Liquid Wrench, but use machine oil, soon.
Look for an "oil hole" on top of the motor; there may be two of them.
Oct 05, 2009 | Lasko 2506 16", 3 Speed, Oscillating Fan
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
GE REFRIGERATOR FAN AND COMPRESSOR DOES NOT WORK, BUT LIGHTS TURN ON.
  • Unplug the power cord of the refrigerator
  • Locate the fan plug (usually next to the water valve), unplug it
  • Try to spin the fan blade by your finger, if it has too much friction, lube it with small motor oil (sewing machine oil etc)
  • Clean up all accumulated dust.
  • Plug it back, it should work (fan motor is thermally protected so it won't burn out)
Jun 03, 2009 | Refrigerators
Area below grinder blade collected residue cannot clean thorough
The base of the blending container is detachble, it should unscrew at the very bottom.
Apr 28, 2009 | Refrigerators
Noisey fan stops when door opens
Fan is supposed to stop when the door is opened . Noise from the fan could be a bearing problem if it is a high pitched squeal. If this is the condition you have , replacing the evaporator fan should correct the problem. If the fan is sounding like a buz-saw the fan blade could be pushed in to far on its shaft, or it could be hitting an ice build-up in the blade turning area.
May 26, 2008 | Refrigerators
Remove blower blade from motor
A guy who has been repairing these for twenty+ years told me sometimes the blower fan is just too tight to remove. If so, you have to use a screwdriver or punch from the motor side and literally break the plastic fan apart. I thought that was going to be my problem, but..... With wrench tightly fastened to the nut at the back of the motor and resting against the post of the rubber wheel, I put a sturdy wrench on the shaft at the front of the motor and whacked it in a clockwise direction with a hammer. It snapped and came loose! Hooray. Try that before you demolish the blower fan.
Jan 15, 2008 | Dryers
Goodman GMS90703BXA Heater Logo
46 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
