Question about Whirlpool Duet GHW9150P Front Load Washer
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is currently some accumulated water in the drum) the washer will not drain and and it makes the same humming noise.
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Posted on Feb 01, 2010
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Finding water in the washer after it sits idle for a few hours. Wife tells me that she completes a wash cycle as normal, moves the clothes to the dry emptying the washer. Then later in the day she returns...
yes its a leaky solenoid water inlet valve,shut off each water fill valve after using the machine and check the drum later to see if its still empty,then do the other4 valve and when you find water then thats the leaky valve,don't try to clean it,just replace the entire valve
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Only a very small amount of water entersn the drum
Sounds like a blockage @ presure switch feed hose or chamber you need to clean both to cure..
Nov 27, 2009 | Bosch Classixx WFL 2066 Front Load Washer
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
208 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
