Question about Hotpoint WMA40 Front Load Washer
It is moving when spinning - Hotpoint WMA40 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
Could be caused by unbalanced load, or broken suspension spring, worn or broken shock absorber, and it is very important that the washer is perfectly level.
Hope this helps.
Posted on Jan 31, 2010
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
I have a kenmore washer model # 110.20722990 will agitate but will not move to the next cycle to drain or spin
If you can manually move the timer to spin and it works replace the timer. If you move to spin and it does not work, replace the lid switch.
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Will not spin
You have either a bad lid switch, a bad drive coupling or a bad timer. If you can move the timer dial to spin manually and turn it on and it spins the lid switch is good and the timer is bad. If you manually move it to spin and the motor runs with no spin, the drive coupling is bad. If you manually move it to spin and nothing happens, the lid switch is bad.
Jun 11, 2009 | Kenmore Washing Machines
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Hotpoint WMA40 Front Load Washer Logo
55 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
