Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
Proform sport 1100 makes sound when the speed
Proform sport 1100 treadmill makes sound when the speed exceeds 2 mph. it looks like it's coming around the roller area, not sure. i'm unable to open the hood even after the screws are removed.
  • visban Jan 31, 2010
    proform sport 1100 makes sound when the speed exceeds 2 mph. it looks like it's coming around the roller area, not sure. i'm unable to open the hood even after the screws are removed.
  • 232 Answers
Roller end bearings will be shot. The will be ball-race types and easily obtainable using the numbers printed on the side of the bearing casing.
The hood must either have a hidden bolt or screw, or it has compression clips as well - you may need to use more force or see if theres a screw under a foot or cap somewhere on the other side of the hood from where you removed the screws.
The bearings may need a 3 leg puller to remove them :)
Posted on Jan 31, 2010
  • 1,428 Answers
Consult your manual.
If you dont have a manual just post the product model and I will work on it.
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Jul 07, 2013 | Proform 400 CT Treadmill - Treadmills
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
I have a proform 580 trainer whose speed fluctuates. if it is set to 4 mph it will go down to 3.2 mph then back up to 4 mph and anywhere inbetween those speeds.
1) Tess by RUN the sofware calibration for easy diagnose, troubleshooting and fix it.
2) adjust the speed sensor, test for open or faulty, clean it and tight the plug very well. see the diagram attached.
3) Test the inclination motor for overheating Try to LUBE
4) Lube the deck belt according with the schedule maintenance.
God bless you
Dec 18, 2012 | Proform XP 580 Trainer Treadmill
Motor noise
tight a little the drive belt, and test and replace the belt if necessary.
2) test the bearing motor and repair.
3) LUBE the deck belt and rollers bearing and replace if necessary maybe you have a WORN deck belt with noise!
God bless you
Nov 21, 2012 | Treadmill Doctor Proform Sport 1100...
My machine turns on but I can't program it to any other speed. It only works at 1 mph. I don't know what is wrong with it. help?
1) Try to change the batteries from your model.
2) If do not have battery( normally under display board) spray with contact cleaner the keypanel.
3) Tight the flexible cable from keypanel vs display board .
4) Tight the connector from display board vs main controller board.
5) Adjust the Reed switch +speed sensor(touch the magnet with another face in the motor).
Oct 03, 2011 | Proform Sport 1000 Folding Treadmill...
Where is the sensor for reading speed and mph
The speed sensor is located on the frame next to the front roller pulley. It will be clamped to the frame on the left side of the treadmill under the motor cover.
The pulley has a small round magnet mounted to it. It may have come loose and attached itself to the metal frame of the treadmill. Check for the magnet, and position the speed sensor as close to the pulley as possible without making contact.
If the speed still doesn't work, replace the speed sensor.
Jan 02, 2011 | Treadmill Doctor Proform 525 Si Treadmill...
How do I fix a problem with the belt slipping?
hi there
it could be 2 things of this problem
1 walking belt slips easy ti fix
1th step; put treadmill in speed of 4 mph and step on side and try with one leg to stop it (be carefull) if you see walking belt stops with align key give more tension from the back of treadmill rear rollers by turning both bolts clockwise same degree with small turns till stops
if it does not help it is probably drive belt
you need give more tension on motor by using 9/16 wrenches
Nov 22, 2010 | Proform Sport 1000 Folding Treadmill...
Proform Sport 1000 - The right hand side of my controls which allow me to change the speed of the treadmill do not work. The left side is still operational and allows me to change the incline and select...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Aug 09, 2010 | Proform Sport 1000 Folding Treadmill...
I have a proform 785..the problem is the speed and incline decreases all of a sudden like within a minute...i raised the speed to 4 and it dropped to 2 within 1 min and same thing with the incline it...
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | Proform 785 CS Personal Trainer Treadmill
Treadmill automatically speeds up upon start up
If you have a unit where the speed can be adjusted with 1 mph increments 0 to 10 and with speed up or down .1 mph increments . it sound like the key pad itself is causing this problem. Depending on manufacturer you can purchase the keypad/overlay and some will want you to purchase the entire display.
Mar 01, 2010 | Proform Exercise & Fitness
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
96 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
