Question about Siemens optiset E Corded Phone
No ringing tone or incoming call sounds.
We have three phone in our offices but the sound just stopped working on two of them. The other features on the phone work, can accept and make calls but no ringing tone? Can u help?
    Problem Solver:
  • 6 Answers
May i know the model
Posted on Feb 19, 2008
The primary phone sets the ring for all phones. If it is off, nothing will ring. Once it is on you may set the volume of the rings on all sets individually. If you have the manual, look under Ringer Off on the main set. Hope this helps, let me know
  • 65 Answers
You may also want to check to see if the do not disturb button has been pushed on the sets that are not ringing.To release do not disturb push the button again.
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Ring tones on KX-T7433
Wow, this is your lucky day :-)
From each phone, press PROGRAM 99 and the INTERCOM or CO buttons TWICE, then dial 1-8 and STORE. (default is 2). You can now make each line and intercom different, or each phone (up to 8) different. After you finish with each phone, just pick up and drop the handset back into the cradle to end programming.
The feature is called Ringing Tone Selection.
Carl
Apr 02, 2009 | Panasonic KX-T7453 Corded Phone
Phone won't ring or vibrate and keys click and beep when pressed
I brought my phone in to my service provider and they removed the battery and sim card (because I was unable to turn of my phone with the power button) and rebooted the phone. It's all good now.
Mar 19, 2009 | Nokia 2600
H500 soft persistent beeping
this sound is the sound of count down from going from a standbye mode to shutting off itself to conserve battery thats all this is
cant stop it unfortunatly its built in feature
Jun 04, 2008 | Motorola Mobility H500 Wireless Headset
Ring tones are all distorted
if you having distorted sounds even if you change the ring style and deafault ring tones' the problem is the speaker buzzer of your phone....:D
Apr 09, 2008 | Motorola Mobility RAZR V3
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Siemens optiset E Corded Phone Logo
649 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
