Question about Sony VAIO Notebook
Blue ray disc plays on laptop but not on tv with hdmi connected
  • 733 Answers
Probably tells you that the current display settings dont work with player. try this, power off(shutdown pc) completely and disconnect hdmi cable. now, with tv on, plug the hdmi cable to pc and power up. it should recognize the tv and run the movie properly.
Posted on Mar 28, 2010
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
When tv is wired to media center and then to blueray dvd , disc will not play. Non blueray disc will play. When tv wired directly to blueray player, blueray disc runs fine. Cables are hdmi
Hi.
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
Oct 24, 2009 | Bose Audio Players & Recorders
Can't play Blu-ray on my TV via HDMI lead
i had the same problem, you need to right click on the desktop when the hdmi lead is plugged in, go to personalize, tasks, option to connect to a projector or other external display, and connect external display only. the blu ray cant play on 2 screens at the same time. my only other problem is that on some blu ray discs, i get as far as the title screen and then cant press play in any way, can anyone help???
Apr 19, 2009 | Acer Aspire 5610-4648 Notebook
Trying to get my Acer Aspire 7720 blu ray player to play on my lg LCD tv. player plays fine on the laptop but not the tv. Connecting thru a VGA able for video feed. Help please
Hi there
You will need a HDMI cable, that is of course if the laptop has HDMI out and that the TV supports HDMI.
This is the only way you will be able to experience the full Blue-ray HD experience through the LCD TV.
Good luck and thanks for using Fixya!!!!
Feb 19, 2009 | Acer Aspire 5100 Notebook
Cant play blu-rays on lcd hdtv connected with hdmi
The software playing the bluray disc (PowerDVD) will only play it on the primary display. You will have to set your tv to be your primary display in order to watch the movie.
This only happens with bluray and HD-DVD discs.
Dec 06, 2008 | Sony VAIO Notebook
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Sony VAIO Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
