Question about Kitchen Ranges
Kenmore range I've got an older electric Kenmore range. Yesterday my wife turned on the oven and said she heard a 'pop' and then the oven wouldn't heat up. The stove top still works. Any ideas?
  • Anonymous Mar 16, 2014
    Have to hold button down for oven to start heating
  • 5,911 Answers
If this range has electric elements in the oven, you may have blown one of the heating elements. Do any of the oven functions work? If you were attempting to BAKE when this occurred, have you attempted to turn on the BROILER to see if it works? If the BROILER still heats up, you may just have a bad heating element. If both features quit working, the problem may be with your Electronic Range Control (ERC) board. Post back with comments and let me know.
Posted on Feb 18, 2008
I have a Kenmore electric smooth top range that I cannot use the oven on.
it sounds like the clock assy. cooked or there's a shorted wire somewhere,did the bake element crack or short out?this also can take out the clock assy.if the part is 150 dollars that 's not bad,some of them cost 300 or more.good luck with your oven,also you should have an electrician come in and put the stove on it's own electrical line.
Feb 27, 2013 | Kenmore Kitchen Ranges
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
My frigidaire fef336ece oven quit working after I heard a pop, how would I repair this?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 20, 2010 | Frigidaire FEF366 Electric Kitchen Range
Oven will not heat
Since bake and broil use different elements, and it is unlikely both went out at once, and then I would suspect the switch instead of the elements.
May 09, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Counter top or oven will not heat up.
Go back to you breaker box. Re-set the breakers on each side of the one you re-set before. Now try it. Thr range works on 220v. This consist of two breaker leavers. One for each leg of the 220v. If you only re-set one leg, only half the things work.
Please rate this solution
Aug 26, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Replaced bake unit in Frigidaire FEF366DCA yesterday and when I turned on to bake @ 350 I heard a "pop" and the oven would not heat past 300 in quite some amount of time. Is it a blown fuse? And if so...
the pop is most likely an electrical short it will be in the back of the stove,that is unless your new element shorted .when cool you can run your hand around it and you should feel no blisters,smooth only.other wise you are doing a visiual inspection and looking for an obivous burnt wire/connection.God bless ,tom
Jan 04, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
433 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
