Question about Whirlpool SF357 Gas Kitchen Range
The temperature on the oven is off by about 20 degrees. What do I need to have replaced in order to fix this problem?
  • 1,531 Answers
Ther can be two problems with this the first thing to check and or replace is the oven temp probe it might be out of toloerance.then second thing will be your main electronic control board,or it is called the clock timer control.
Posted on Jan 31, 2010
What needs fixed in my built in Tappen oven, model 12-1263-30, when it is 90 degrees off?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
The normal operation of a oven is the oven will rise 20-40 degrees above the set temperature and turn off. Then, when the oven temperature drops 20-40 degrees below the set temperature it will turn back on and cycle again. This is true except for the new accurate ovens.
Since you are getting heat your oven heating element is good.
You have a older oven.
Your problem is either the oven thermostat which cost over $200.00.
  • MFG Number 5303202782
25691587-pfxp0re3pkk4llvjptchxxrl-3-0.jpg Or, your oven control, which base on your oven age is no longer available.
Now, here are your choices:
1.) Take a chance and purchase the oven thermostat and install it. If this does not solve the problem you can return it less shipping and restocking charges.
2.) My professional recommendation is to put the old girl to rest.
You can:
a.) Go to a Sears Outlet (Scratch and Dent) Store, save a couple of hundred dollars on a new oven and still get a one year warrantee .
b.) Go to a used appliance store.
c.) Go to Habitat Stores - used appliance stores.
d.) Go to Second Chances Stores - Appliances removed from homes that were torn down.
Best of luck,
Peter
May 11, 2015 | Kitchen Ranges
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
LG LRE30451 won't maintain temperature
Check the oven temperature probe (thermister) to see if it is good. To check it, use a multi-meter and Ohm it out. It should be between 1100 and 1600 Ohms. If it is out of tolerance, you will need to replace it. Here is the part to order.
Nov 30, 2012 | LG LRE30451 Electric Kitchen Range
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
How do you fix the temperature for the whirlpool oven
Buy a oven thermometer to put inside the oven to check the accuracy of your oven temp setting. If the oven temp is not too far off from what your oven thermometer is reading, you can recalibrate the oven knob. Pull the knob off and look at the back. You can adjust the degrees approx +or - 20 degrees. If the temp is all over the place or just not heating up enough, then it's time to replace the oven thermostat, assuming the oven isn't too old or not worth fixing.
Douglas
Oct 05, 2010 | Ovens
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
Kenmore Electric oven is not getting up to the proper temperature
Look closely at your knob. I bet it is cracked.
Jun 10, 2009 | Kitchen Ranges
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Whirlpool SF357 Gas Kitchen Range Logo
66 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
