Question about Refrigerators
Overflow tray why does the overflow tray underneath the fridge keep filling up with water? it has done it twice in the last 24 hrs, never done it before.
    Problem Solver:
  • 6 Answers
Check to make sure that the doors are 'sealing' all around the face of the gasket. If not, it is pulling outside (moisure laden) air inside, condensing, and then draining out to the drain tray on top of the compressor. Replace the gasket if it is not sealing!!
Posted on Jan 31, 2010
Testimonial: "this was very helpful, we will check the gasket."
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
My Liebheer stand alone fridge is filling up with water in the bottom of the fridge.
This is due to the defrost water condesing and overflowing out from the drain tank.
So keep the fridge in a normal temperature and make sure that the tank is empty. Also check if this is an overflow or that the drain hose is leaking from the top of the evaporator collecction tray. If so check out the leak point and patch up.
Other wise if the fridge is working fine all what is needed to check out using a good inspectiion lamp, check the tilt of the fridge and set using a water level.
Jul 25, 2011 | Liebherr Refrigerators
Icemaker overflows water , repairman has replaced the icemaker twice, after this last time, it started making 1 tray of cubes per week, then after about 2 weeks, started overflowing water again.
Good day,
If it is erratic as you describe and replacing the ice maker twice has not resolved the issue it would make sense to replace the water valve in the back rear of the machine, if it hasn't been done so yet. It's the flakiest part of the system and has the highest failure rate. It's been known to fill too little, to much, and sometimes not at all.
May 26, 2010 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
GE model tfx26krda side by side refridgerator/freezer
If the drain catch tray is full the unit will overflow. Look underneath in the rear/fron of bottom the fridger to remove and empty the catch tray. If there is food or debris in the bottom of the fridge (drain grates) it will keep water from going down.
Sep 14, 2009 | GE Hotpoint Top-Freezer Refrigerator
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
My ice maker is turned off, but water slowly seeps into the tray
Try turnig off the fridge and let it defrost,keep the doors open and put pans of hot water in the freezer,wait 6 to 12 hrs.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Water dripping into fridge from freezer.
Hi. thanks for the question. You have a problem with the drain tube, from the freezer ,to the tray underneath the fridge .Best way to clean. Turn power off to fridge. Let defrost for 24. HRS . pull fridge from wall remove back panel clean all coils locate the drain hose at the drain pan clean . Thanks the appliance doc
Sep 30, 2008 | GE Refrigerators
Refrigerator has water leak
Had the same problem with mine. Got a technician to have a look. Inside the fridge at the back there's an overflow tray. CHeck if this is not blocked. Clear it by putting a tray behind your fridge under the overlfow pipe and pour hot water through the overflow tray inside the fridge. Sometimes food gets stuck in there and nobody thinks to clear this out. Mine was easily unblocked and now its stopped leaking.
Apr 14, 2008 | Refrigerators
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
