Question about Craig Televison & Video
Lcd tv digital tuner
15" craig hdtv lcd won't get any channels using rabbit ears in a room where I don't get cable.
    President:
  • 2,992 Answers
Welcome to the world of off-the-air broadcasting!
First, be sure you have the TV set up correctly and that is in fact capable of digital tuning. Just because a set was sold as HDTV doesn't mean it has a digital tuner. Small TV sets weren't required to have digital tuning until shortly before the switch from analog. This set may require a digital adapter. If the set does have digital tuning, be sure you have "air" selected and not "cable" for your tuning mode. Also let the set scan for channels.
With digital broadcasting, signal strength is critical. In the analog days, a weak signal would give you a fuzzy picture, but you could see something; with digital, a weak signal means you see nothing at all. You may live in an area where the signal is too weak without using an amplified indoor antenna or putting one on the roof. Your location, other structures around and weather conditions all affect digital reception as well. Many people were (and still are) upset to find that they just couldn't get any channels at all once digital broadcasts took over.
I hope this has been helpful. Thanks for using Fixya!
Posted on Jan 31, 2010
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
Can I use a regular antenna
Yes. You can use a regular antenna for any flat panel HD TV. You're only limitation the type of antenna and whether or not your flat panel TV has a built in digital tuner. If it does, you'll be able to scan for digital channels without any additional components, including the High Def ones,  though you may not get every channel available with a set of rabbit ears. A roof top antenna will give you a stronger signal and more channels. If your TV does NOT have a built in digital tuner, you'll have to purchase a digital converter box and attach your antenna to it to receive the digital and HD channels. Good luck.
Jun 30, 2009 | Panasonic Televison & Video
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
Jun 22, 2009 | Televison & Video
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Tv set just lost its ability to display digital channels
Your problem is definitely the input signal source to your tv. It is extremely rare where a new tv has a tuner signal sensitivity problem. The best thing to do is to replace your current set of rabbit ears with a different set of powered rabbit ears that have a higher gain rating with a variable gain control. Please note that the gain control setting is critical when setting up your tuner for auto-programming. If the gain control is set too low or too high it will result in your symptom.
If you still can't get it to work you could try buying a line amplifier which you would install to the rabbit ears before the tv. If you still can't get it to work you'll have no choice but to purchase an outside antennae as a result of your being in a weak signal area as signal quality changes by such things as the switch over to digital upcoming and environmental changes.
Apr 27, 2009 | Televison & Video
Can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Jan 28, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
No HD
Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
Mar 15, 2008 | Protron PLTV-4250 42 in. LCD Television
No cable hookup
harvque- you can use rabbit ears to get the local free channels,but you will probably need to extend the wires and try to mount them outside.The main reason is because the newer tv's with digital tuners don't pick up as well as old school tuners,and the tv signals are not as strong cause they are usually boosted as the are wired in.Try this and let me know,I do have a few tricks for free air tv. cooltekFeb.18/08
Dec 30, 2007 | Durabrand DWT1304 13" TV
Televison & Video Logo
312 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
