Question about Kodak EasyShare C913 Digital Camera
The lens do not go back in,power comes on then turn off.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 31, 2010
Fuji finepix
When a camera notice the lens does not move, it is afraid to damage gears or the motor, of it powers down everything involved the lens. It then gives a message as you read.
Because the camera can't know what is casing this, it only can warn.
It "hopes" if it did run the lens to an obstruction, powering it down will relieve the tension. That is way it says power down.
Remove the battery, check the lens barrel if any obstruction is limiting the free movement of the lens. and then replace the battery. switch it on again.
If you accidentally touched the lens, while it was coming out, it could have given the same error. When after switching on the camera, and you are sure you don't obstruct the free movement of the lens barrel, but it comes back with the same error, you should contact a certified repair centre for your camera.
Jul 20, 2014 | Fujifilm Finepix S2980
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
When I turn the power on, green power light comes on, lens comes out half way but then freezes and green light goes off, camera unresponsive. battery is fully charged and I have taken it out and put it...
Hi.
This is a common problem , generally indicated as lens error. The problem is often caused by dirt or dust in the lens gears.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
You can attempt tapping gently the back of the camera while turning the camera on. Sometimes this can help the lens out.
If that does not work, then the lens must be taken apart.
I summarized the problem in this article: Lens Error.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Regards.
Aug 09, 2010 | Canon IXUS 960 IS Digital Camera
Turn on power, green light flashes, powers off
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Rokinon DZ1000 Digital Camera
I cannot turn my camera on.
If The Lens Is All The Way Out And Wont Go Bak In Thats Why The Camera Wont Turn On Not The Other Way Around. Try Very Gently Turning The Lens And Turning The Camera On At The Same Time Till U Hear A Click That Should Do The Trick.
Feb 09, 2010 | Samsung SL420 Digital Camera
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
Fuji FinePix F700 LCD & Zoon Lens
Is the battery fully charged? Or is the battery near the end of its useful life? Some batteries hold a charge better than others-- I have 2, both used well, and one seems to last longer than the other...
Aug 25, 2008 | Fuji FinePix F700 Digital Camera
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
This Sucks!
take it back the motor sounds faulty
Jun 07, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
=[ wont work
If the lens does not extend then it is possible that it has become jammed. Somtimes this can cause the camera to sense an error and shut itself down immediately after powering on. There are other explanations for the behavior, but if the lens does not move this is the most likely cause. If the lens does extend but then the camera shuts right back off it is possible that an inner component such as the focusing element is not functioning properly. When a camera comes on and then turns right back off it is generally due to some failure in its self-check at power on. Most of these failures come from the lens due to the fact that it contains most of the moving parts. Check with your manufacturer for warranty support or recalls. Failing that you can find an online repair provider who can fix your camera. David Millier Advance Camera Repair
Mar 12, 2007 | Olympus FE-130 Digital Camera
Kodak EasyShare C913 Digital Camera Logo
67 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
