Question about Bang and Olufsen Beocenter 9300 Shelf System
Bang & olufsen stereo unit 9300
I Repositioned speakers and the system played ok and I then disturbed the speaker connections to the set, creating loud noise from the speakers and now all of the items work, cd, tape and radio but no sound from the speakers?
Any suggestions?
  • Anonymous Mar 18, 2014
    the system makes a bad sound and the tone arm doesn't move when I push play button
Following advice from Simon at Avaservices.co.uk, I double checked the speaker switches and found that whilst handling the speakers I had moved one switch to line.
This I corrected and then double checked the cable concealment to one speaker and found that possibly one of the carpet strip tacks may have moved the cable position whilst refitting the carpet and caught the cable?
This was repositioned and the system tested. Absolutely terrific!
Thanks all round!
Posted on Feb 19, 2008
  • 56 Answers
You probably burned the speakers.If you have the multimeter check the spekers for the resistance.It has to be 4 or 8ohms otherwise they are burned.And you have to check voltage on the amp connectors for the spekers.if there is any DC voltage presens the amp is also burned
My beosound 9000 plays only over one channel
if the other rooms are connected via masterlink the problem is in the main unit, have you checked the balance control
Jan 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Our beocenter 9300 will only play at a low volume (of about 4 bars). You can increase the volume a bit, to about 8 bars, but not for long. The volume drops to about 4 bars in just a few seconds. What is...
TRY REMOVING THE SPEAKER CABLES AND LISTEN ON HEADPHONES,IF THIS WORKS THEN SUSPECT SP WIRING BUT MAY STILL BE AN INTERNAL FAULT IN UNIT EITHER OUTPUT OR P SUPPLY.
Sep 09, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
I have a beomaster 2200 and the sound will only come from one speaker, I have checked the speakers and these are ok. When I move the balance control I get a loud crackle noise. Many Thanks John Bailey
if the loud crackle noise is in the speaker that doesnt work you may have a problem with the balance control itself or int. contacts in the switchbank.clean and lube both for starters.
Oct 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
B&O - 3300 Hum noise only
you can download a repair manual for free at beomanuals.com before you start working
May 25, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Where can I buy speaker stands for S45 B&O system and also antenna for beocenter 4600. Circa 1977
s45 speakers are from the late 1970s so unlikely to find stands.4600 can use indoor aerial with either 300 or 75 ohm connection.
May 15, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Connecting a sonos 90 to BO 8000 active speakers
Does your sonus system has pre-out? you can directly connect one single rca cable to each output into the speakers. make sure, each speakers is set to left and right each channel. these switches can be found above the rca input of the beolab 8000 next to the power link input. You have to understand that by using powerlink source cable is ideal only for other bang&olufsen equipments......however, there are other options, if u don't have a pre-amp output of your amplifier, you can also modify the speaker out of the amp, thru a conversion cable available from bang & olufsen, with an rca cable left and right channel, without interfering with the powerlink.
Apr 03, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Beomaster 5000 receiver, no sound out of left side
if you connect a pair of sp to sp2 outputs only and the l/h is dead check balance on mcp5000 it may be over to the right.
Feb 16, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
437 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
