Question about Gateway FPD2275W LCD Monitor
Acer 1711 monitor won't power up
Plugged in, screen stays blank. Connected computer, no change. The green power LED flickers weakly, and there is a faint clicking at 1Hz intervals coming from inside the case (power supply?). No other signs of life. I guess this would apply to any size monitor, not just the 17 inch. Any ideas? Thanks
  • 1 more comment
  • madmacman Feb 21, 2008
    I opened up the monitor, and the power board looks fine - no poor soldering or overheated components or affected circuit board. The power supply looks like a switched mode type. The warning says High Voltage. The only large electrolytic is OK. What is my next step? Thanks
  • Monica Chiasson
    Monica Chiasson May 10, 2008
    My AL718 won't power on.
  • Anonymous Aug 08, 2008
    How does one switch ac power from 115v to 230 volts?
    Champion:
  • 220 Answers
Power supply of the monitor is the culprit.Generally defective electrolytics in primary section of Power supply.
Posted on Feb 19, 2008
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
X241W Acer monitor: getting blank screen. When unplugged and plugged back in, it powers up, stays on for about 10 seconds, then goes blank again. Green power light stays on. Have connected to different...
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 15, 2010 | Acer X241Wsd Monitor
I have an Acer AL1711 monitor and its got a blankscreen
Sounds like bad caps in the power supply. C6 & c22 often need replacing. Check also R1, 10 ohns.
Monitor Mike
Apr 14, 2010 | Acer AL1715 17" LCD Monitor
I have an aspire 1711 SMI, who doesn't work properly since several months. The display was starting to fall down and now there's no diplay at all, completely black. Now, when I start the notebook, the...
Hi
This is a common problem. The problem is the inverter. I changed mine OK. Actually I changed the inverter once and the whole LCD screen twice! Now happy with working 1711.
two inverters here on ebay
http://cgi.ebay.com/ACER-Aspire-1700-1710-LCD-INVERTER-1702-1711-1712-1714_W0QQitemZ150404840875QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3bdab
http://cgi.ebay.com/Acer-Aspire-1700-1710-lcd-inverter_W0QQitemZ150404836278QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3abb6
search this massive thread and you will find instructions on fitting the inverter.
http://www.notebookforums.com/thread19756.html
Cheers
Oct 05, 2009 | Acer Aspire 1710 Notebook
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Oct 12, 2008 | Acer AL1714CB (Black) 17" LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
599 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
