Question about RCA 20F514TD 20" TV
I recently purchased a rca tv model j24f635 without the remote. some channels have be deleted and i have tried to add these channels back but haven't been able to. how can i add the channels back
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
  • 520 Answers
SOURCE: Input
Use a RF Modulator. This will allow you to connect the dvd to the antenna jack of the tv.
Posted on Sep 04, 2008
  • 899 Answers
SOURCE: Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Posted on Oct 06, 2008
  • 76 Answers
SOURCE: can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Posted on Dec 03, 2008
SOURCE: Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
Posted on Feb 02, 2009
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
HOW CAN WE CHANGE TO AV ON HITACHI TV WITHOUT
Try this! Get into the menu and look for channel setup. See channel memory delete or save and add this to channel memory. Hope this works..I never repaired this model. This is only a suggestion.
Dec 23, 2009 | Hitachi 43FDX01B TV
Noticed that all of a sudden i can't get channels past 20 and i have several other tvs in house on same cable line (without box) that get 99 channels
you need to access the menu in the remote control and go to add/delete channels and this should open up the channels
Nov 14, 2009 | RCA TruFlat 27F520T 27" TV
Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
May 13, 2009 | RCA F25216BC 25" TV
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Can't get TV onto the AUX channel
Sep 09, 2007 | RCA F25254GY 25" TV
RCA 20F514TD 20" TV Logo
123 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
