Question about AEG Dishwashers
I have disconneted a pump to the Beko D3422FS to check and clean the impeller. Sadly I didn't take clear enough notes on the wiring connections and the macine is now tripping the mains. Does anyone have a wiring diagram for this, or even just a photo of the pump connections in situ.
I downloaded some circuit diagrams from rapidshare after contacting an expert on justanswer.com.
http://rapidshare.com/files/344031734/d3422fs_2.pdf
http://rapidshare.com/files/344031301/d3422fs.pdf
Alternative locations:
http://ww2.justanswer.com/uploads/Techdesk/2010-02-01_072933_d3422fs.pdf
http://ww2.justanswer.com/uploads/Techdesk/2010-02-01_072958_d3422fs_2.pdf
There are three wires on the base of the motor, Red, Brown and White.
The White conects to the double violets on a conector
The Red to one side of the capacitor (side nearest the motor)
The brown one caused a lot of confusion. I believe this attached both to the yellow connection and then onto the spade connection on the other side of the capacitor.
This is one I slept on, and had an Epiphany.
The circuit diagrams didn't apear too clear to me. They don't sem to indicate which connections go to the capacitor, just the pump cluster as a group. I may be wrong, but have connected as above and will get the father-in-law to check them before I plug the machine back in.
Posted on Feb 01, 2010
How to clean debris from impeller? Pump is not drawing water from the skimmer/pool .... I'm hoping the impeller is clogged and not something more serious like a shot motor.
There are normally 4 to 6 bolts around the outside connecting the wet end from the dry end. Undo those bolts and the front of pump should come away. Then you should be able to see impeller. Using a piece of wire poke it through each slot of the impeller to clear the blockage. Then put back together again. Remember to prime the pump
Jan 30, 2017 | Pool & Spa
Beko WMI71641 won't agitate or spin - drum doesn't move!
your pump is blocked,at bottom of machine there should be a flap with a round plug in middle .unscrew,it will have water come out so use a bowl or big towel.the impeller should turn freely,once plug is unscrewed at front put washer into a drain program see if the pump turns.if this is free youll need to get the pump off(unplug machine first)and then feel inside the big pipe from the drum to pump.it may have a sock or something like inside.this means it will work but wont get out all the water.also note when trying to spin a pillow,or big towel the load will be uneven so it will reduce its spin speed so it doesnt destroy its self
Apr 16, 2014 | Beko WMI71641 Built in washing machin
Wont do final spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more beko test videos at site
Dec 02, 2011 | Beko WME7247W Washing Machine
Water didn't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 19, 2011 | GE Nautilus 24" Built-in Dishwasher
Hi there, our dishwasher hasn't drained. we are assuming that it may have something to do with the pump. Is there anyway that we can see if it's the pump before we call someone in to look at it? Or...
Hi and welcome to FixYa, I am Kelly. Without your model number this is a very GENERIC response. With a MAKE & Model number I could pass exact steps as to how to go about troubleshooting. Having said that here goes. You did not mention if the drain pump was running and it was not draining so for the mopment I have to assume the motor is running but the unit is not draining. Do the following steps:
1. Remove the drain hse from the sink connection and check the drain port for a clog. This is usually a garbage disposal connection but it can be a direct connection. Re-connect the drain hose after checking / clearing the drain port.
2. If you have an Air-Gap on the back of your sink or near the dishwasher, lift the cover up and off of the Air-Gap. In the very top of the Air-Gap there is a plastic threaded nut you must unscrew to gain access to the the drain plumbing in the top of the Air Gap. NOTE the installed position of the cap as it will only install one way. Remove any debris in this area. Use a wire coat hanger and a flashlight if necessary to clean the port that exits to the sink connection. The open plastic tube you will see is the connetion from the dishwasher. This should also be clear. Reassemble the Air-Gap in the same manner as dis-assembly. Reconnect any hoses if you removed any to clear drain ports.
3. Make sure power to the dishwasher is secured and remove the lower kick panel. Remove the drain hose from the pump housing and check for debris in the pump and pump port. Clear out any debris in this area.
4. Here is where not having the model number comes into focus. Without that model number the procedures for checking the tub sump and impeller are drastically different. The bottom line is the lower wash arm and support are removed.. any sump covers are removed and the screens / fins in the sump area are to be cleared of debris. Dome units the impeller is in the sump... other units the impeller is in the motor pump assembly that has a macerator before the pump inlet. If the inlet to the pump / motor is clogged it must be cleared. On units that have the motor pump assembly directly in the bottom of the unit there can be 2 levels of water flow. Upper for dishwashing and lower for draining. All passages in this area must be cleared.
Steps 1 and 2 above fix about 80% of the drainage problems. Test for drain function after steps one and two.
Thanks for choosing FixYa,
Kelly
Jun 18, 2011 | Dishwashers
I have a lg front loader mod-wd-1025fb washer, i moved the other day & i have just connected the machine up to wash & it fills up with water but wont spin it out & just stands still has a OE...
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 29, 2010 | LG WM-2277HW Front Load Washer
My whirpool duet washer is displaying F33 code. It doesnt spin at a high rate of speed to allow for the clothes to spin dry therefor the door latch will not open.
The F33 error indicates a PUMP DRIVE SYSTEM ERROR and occurs when the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Plug in washer or reconnect power.
4. Verify CCU operation by running a Diagnostic Test or any cycle.
System Leak - Select 'cancel' twice to clear error code. Check for any cracks or holes in the washer tub or pressure switch hose. Replace if damaged.
Also
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CODE F02 DISPLAYS ON MY KENMORE EVEN AFTER I REMOVED ALL DEBRIS FROM TO PUMP AREA AND HOSE
If the error code persists, any of the following could still be a possibility:
1. Check the electrical connection to the drain pump and make sure it isn't loose.
2. The drain pump may be damaged. If anything was lodged in the pump for any significant period of time, it can cause irreparable damage to the pump impeller or motor.
3. Verify ALL drain lines - this includes the line from the bottom of the wash tub to the inlet side of the drain pump. This is a common area for small articles of clothing such as socks and undergarments to get caught. I know you said you checked the drain line, but did you check the line on the inlet side?
Even if the pump runs, if it does not complete the drain cycle within 8 minutes, the error code is generated. The impeller may be slipping on the motor shaft and not pumping water. Or, the motor could be damaged and not pumping enough volume. If you have verified everything, and cleaned out the pump reservoir, the manufacturer recommends replacing the pump.
Replacements can be ordered on line at searspartsdirect.com or appliancepartspros.com.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: If you haven't done so already, you can also try unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU) to see if the error code will clear. This is the main computer for the washer. Sometimes resetting the CCU will clear some error codes. If the error code persists following a CCU reset, you have a legitimate problem.
Jul 10, 2009 | Washing Machines
BEKO D3422FS
check that there are no kinks in the drain pipe or that the pipe way is clear.
Thanks J
Oct 23, 2007 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
220 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
