Question about GE Dryers
GE space saver gslp1100a0ww how does dyrer attach to base?
GE space saver gslp1100a0ww how does the dryer attach to base
I went to a retail outlet and looked at the product and figured out what to do.
Job complete.
No help from you.
Posted on Feb 01, 2010
How can I remove the front panel of a GE space maker dryer when access to the machine's rear, top and bottom is limited?
I don't know the model but as its a compact model, I would think its a 1 piece cabinet. These can only be accessed from the rear. You will have to lift it down and work on it on the ground.
Nov 30, 2015 | GE Dryers
Hole in wall
The hole was probably put there for a dyrer vent, which is very important to have. They allow heated moisture vapor to be expelled outside and helps keep excess moisture out ot the home. If this is the case, any home improvement outlet will have the stationary wall plates and the outside flap mechanism. The flap shuts when not in use and keeps outside elements out of your dryer......including critters. If your dryer is vented already, just cover the inside of the old hole with a piece of panelling, insulate the hole space, and attach a metal cover over the outside of the hloe. Make sure you seal the outside with caulk or another sealer.
Sep 07, 2014 | Dryers
GE dryer dcvh680ej0ms runs 3 minutes and shuts off and resets time
On esimple thing to try is clean the dryer moisture sensing bars inside the dryer. Wet clothes rub against these bars and tell the control the clothes is still damp. IF no moisture is detected then she shuts down. So what goes wrong? Dryer sheets have a waxy buildup on them which tends to coat the bars. Moisture cannot penetrate the barrier and therefore the control thinks all is kosher and shuts down. Energy saver feature don't ya know. LOL Rocket scientists no longer have a space shuttle program so they engineering dryers now. LOL
Houston we have a problem.
Aug 03, 2012 | GE Dryers
My electric GE dryer stopped working today, when
sounds like the motor is running, the belt could likely be broken and be the culprit, this is if the motor is turning for sure after you start the dryer
Sep 30, 2009 | GE Dryers
GE space saver Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My space saver dryer will not get hot ,everything else works fine
If everything else works, but not heating, than the problem is either:
Clogged air ducts
or
Heating element needs to be replaced.
Jun 05, 2009 | GE Spacemaker Washer and Dryer Electric...
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
181 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
