Question about JVC AV-32D305 32" TV
My tv turns on fine after a few min the picture go's half black,if I whack the side the picture will come back on for a while and go back to half black again, could this tv be fixed?
    President:
  • 2,992 Answers
The set has bad solder connections, specifically in the vertical output section. When you whack the set, the connections work for a while so the full picture comes back. Then, when they open up again, you're back to black. A service technician with a soldering iron could fix this easily, and the cost would be far less than the price of a replacement.
Posted on Jan 31, 2010
Testimonial: "thank for the help will call service tech."
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
Dec 19, 2013 | Insignia Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Blacks out for 1-30 min. then back on. Standby light blinks 4x
I would suspect the circuit board around the HV transformer area to have a crack circuit print. Also look around in the vertical circuit for interment solder connections. But only do these things if you have some knowledge of TV circuit lay out. If you do not feel confident then call a professional. No sense in hurting yourself or damaging the the set worse.
Hope this helps,
Skyassoc
Jun 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
Apr 10, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
Please Help
The problem is probably a faulty IC (chip) or capacitor on tv main board.
Only simple things you can do at home are hard reset and whacking test.
To do hard reset leave the power cord unplugged for two hours; then power up again. This will drain power from tv and will restore all eproms inside the set to factory defaults.
to do whacking test. Just bang (not too hard) your fist on the top, back, sides, etc., to see if you can restore the picture, this can fix bad connectors etc.
If reset and the whacking doesn't help, then the problem is in some faulty or burnt component on main pcb inside tv. Often the jungle IC chip. The jungle IC handles all the video, color and control signals to the projection tubes. It is quite expensive to replace. In this case you will need a tech to test and diagnose the exact failure so that the right outboard parts are replaced at the same time.
The set should be nearly 10 years of age; so, it should have a few years of life left in it, as average life for a Toshiba is around 15 years . So, if you have to spend $300 to fix it and you get another 5 years of life or so out of it, it may be worth repairing, as the only other option is buying a new TV.
Aug 14, 2008 | Toshiba TZ50V51 50" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
Picture flips from color to black and white continuously
I believe your set has a loose conection that needs to be resoldered ,every time you hit it reacts and that is good,you need to use a wooden or rubber handle to tap in the main board,around the tuner and in different areas until it reacts,be attentive when it does so you can flip the board and resoldered the area that made it react,once the problem is corrected you need to resoldered any other overheated areas and there should be a few in your set,check the grounds in the tuner(where the coax goes in the inside,is a silver box),the horizontal driver transformer and output transformer.Be careful while you do this and stay away from the thick red wire going to the back of the picture tube specially when the set is on. Let Us know how it goes or if you need more information.
Nov 08, 2006 | Sony KV-32FS13 TV
JVC AV-32D305 32" TV Logo
150 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
