Question about Kenmore HE3T Washer
How do I remove the bottom front panel on the washing machine?
  • 34 Answers
First, unplug the washer for safety. Then remove the three 7 millimeter or t15 torque screws from the front lowest part of your washer - which will allow you to remove the lower front panel. It will be easier if you prop the front of your washer up on a couple pieces of wood or bricks first, so you can get to those screws more easily
Posted on Dec 09, 2010
Where is the filter? And how do I remove front panel?
It's probably behind a panel at the front of the machine at the bottom nearest the floor. The panel will clip or pull off. You haven't specified what model your machine is!!
here's an example video How to clear blocked pump on your Hotpoint Washing Machine
May 18, 2014 | Washing Machines
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Solution for washing machine
  1. remove top cover.
  2. Remove soap dispenser draw.
  3. unscrew the screws securing the the soap dispenser to front console.
  4. Pull timer dial off, noting position of symbols.
  5. slide console panel to right, and lift up out of way of front panel.
  6. Undo 3 screws securing top of front panel.
  7. undo 2 screws securing door interlock to front of panel.
  8. Remove plastic clip securing door seal to front of panel.
  9. remove wire clamp band round front of door seal.
  10. Undo 3 screws at bottom of front panel securing it to cabinet .
  11. remove front panel.
  12. Unscrew thye top wire clamp band securing the seal to drum front.
  13. remove door seal.
  14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
  15. reassemble in reverse order.
  16. Please rate my solution.
  17. Thanks.
Nov 06, 2009 | Washing Machines
The lock for the door is stuck how can i unlock it
You need to remove the top cover, and release the door catch from inside with a screwdriver or similar.
Thanks.
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do you remove front panel on a Bosch WFO285SGB
This video will show you how to replace the Bosch WFO285SGB washing machine door seal with step by step guide on the process
Aug 13, 2009 | Bosch Washing Machines
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Wash machine won't empty the water.
There is a filter behind the bottom front panel of washer. Remove bottom three screws and remove panel. Get something to catch water. Unscrew filter. Clean out filter drain. Should be good.
Jan 02, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore HE3T Washer Logo
269 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
