Question about Sony Televison & Video
Wega KDF-E50A10, no picture, standby lamp flashes
No picture, standby lamp flashes red 4 times
  • 1,476 Answers
You have a problem in the vertical drive section. Probably need to replace the vertical IC and maybe associated resistors. Let me know how you make out.
hardrocko
Posted on Jan 31, 2010
Testimonial: "Thanks for the info. Seems crazy to have to replace something like this for a 2 yr old TV. Any idea what cost I'm looking at?"
I replaced the lamp in my Sony E50A10 and the tv still doesn't power up.The indicator flashes red.Any ideas?
if its the lamp indicator flashing its an issue with the lamp. If the lamp is new I would double check to see if its making contact completely when its slid in often the pins can get bent slightly. If it were the ballast the power indicator would blink 5 times.
Feb 09, 2013 | Sony Wega KDF E50A10 TV
I have a Sony KDF-E50A10 Grand WEGA LCD. The picture cuts in and out and the green standby light flashes. One expert said the STKs need to be replaced??? How can I do this...please advise in detail.
Replace your lamp. Your DLP set does not have Stk ic's in it. I don't know what expert told you that but I can assure you he has never worked on a TV. You can purchase the lamp from www.dlplamps.com
Jan 18, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Why does my sony vega keep turning it self off and back on again
Im guessing it is doiong this about every 30 seconds or so. Im also guessing that when the sound and picture go out, the green standby light flashes until the set comes back on. If this is the case, mine was doing the same thing. I did a bunch of research. I replaced the lamp and the tv is like new, no more problems. The lamp light on the front of the set does not come on because the lamp/bulb is noot burned out all the way. I bought my lamp from www.vanns.com , the best price I found.
Oct 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Jul 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
159 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
