Question about Dryers
Whirlpool Dryer extremely hot
When the dyer is plugged to the power source, the dryer gets extremely hot. It has even melt the plastics in side the dryer. I took the back off and cleared all lint issues. There was nothing blocked. I did find a thermal component burnted out. Two red wires were hooked up to it. I may replac the part but it really seems like the heater element is running wide open. The component is on the bottom of the heater element. Do you have any suggestions?
  • 5,911 Answers
If your dryer heating element does not cycle, you may have a bad high limit thermostat. The thermostat is used to regulate the internal temperature of the dryer and should cycle the heater on and off. The thermal cut-out is supposed to prevent the dryer from overheating and will blow like a fuse. It is a non-resettable device and must be replaced. It is strongly recommended that you replace both these components at the same time if you have found one of them to be bad. Both of these components will be mounted on the heater box housing. Usually the thermostat is the component closest to the ceramic terminals of the heating element. Most manufacturers sell these two components as a set. The dryer temperature at the exhaust on the back of the dryer should be about 140 degrees. If the temperature is excessive to the point where it is melting things and the cabinet is too hot to touch, make sure the heater is regulating as it should. I would use some extreme caution about using your dryer until you have this problem corrected. I would not use it under any circumstances if you are not going to be home, or if you are going to bed. Dryers are one of the number causes of fires in homes. Good luck to you and let me know if I can help any further.
Posted on Feb 18, 2008
Dryer (electric) cord and outlet get extremely hot when dryer is on. I even think it is melting the prongs to the cord.
for some reason the dryer is drawing too much amperage. maybe the cord connection inside the dryer is loose or falling off? i assume this is an electric dryer?
Apr 05, 2014 | Dryers
Why my dyer willl not get hot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Whirlpool LER5636P Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
How do i check the fuses on my dyer ? MY dryer has no heat
i am always suspicious of the timer when an electric dryer loses heat. pull it and check it. or just open it up. look for blackened or melted contacts. good luck
Nov 10, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore series 80 power cord melted
This is extremely distressing to me. If someone advised you to jump acoss (bypass) the thermal fuse on the dryer then I am in disagreement. My advise is to trip the breaker at the house power center, remove and replace the dryer main power cord, and replace the thermal fuse. Something is causing the dryer to pull more amperage than it should be, which is what resulted in the melted cord to begin with. You may want to contact a qualified appliance technician to assist in throughly checking the electrical system on the dryer. Until this condition is properly addressed there is a very real safety issue. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 27, 2009 | Kenmore 63942 Dryer
Prong on dryer plug gets hot and burns plastic on plug
You are right. There is not a good connection somewhere. When you say your replaced the cord, did you also replace the plug? Make sure all fittings are tight. Where it is melting, this is where the problem probably is. You can also check the receptacle and see that the wires to it are tight as well. There is a build up of heat or resistance in that area tha tis causing your problem. let me know how you do. Good luck.
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric Dyer Problem
most of the time the dryer vent hose,wall vent and dryer vent hole must be clear to allow the dryer to vent,also you can pull dryer hot put you hand on the dryer vent hole turn on and see if it is venting this will let you know if the blower wheel is turning, let me know what you find-mike
Sep 25, 2008 | Whirlpool Dryers
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
Dryers Logo
653 people viewed this question
Top Dryers Experts
Marvin
Marvin
