Question about RCA RT2280 System
I have a RCA home theater surround receiver RT2280 and i am trying to use comcast custom remote to control it and no codes they provide work for this receiver
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Posted on Jul 02, 2008
SOURCE: Code for Comcast remote for Sony DAVHDX275
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Posted on Nov 08, 2008
  • 247 Answers
SOURCE: Can't find the code to program RCA RTD207 dvd home theater system
try these codes:
  • 178
  • 184
  • 205
  • 218
  • 224
  • 228
here is another way to program the remote:
  1. turn the device you want to set
  2. aim the reomte control at the device and press and hold down the code search button for at least 3 seconds until the red led lights up solid red
  3. press the device button you wish to program tv, vcr, dvd,etc and the led light will blink once and then remain solid red
  4. press on/off slowly and repeatly until the device your trying to program shut off
  5. once this occurs press enter button to store the code and the led light eill turn off
thanks
tom
Posted on Jan 08, 2009
SOURCE: comcast on demand custom dvr 3 device codes for sony dvd-hdx576wf
I have a Sony DAV-HDX274 Home Theater and the power and volume buttons work now. Thanks!
Posted on Feb 25, 2009
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Posted on May 03, 2009
HOW DO i CONNECT MY RCA RTD325W SURROUND STYSTEM THROUGH MY COMCAST BOX AND MY TV
Video out on rtd325 to Video in on TV, set tV to correct input source, not red/white cables to Audio or AUX INPUT on the rtd325 and run those to Audio out on the comcast box, set rtd325 to AUX fcuntion when watching comcast
Oct 29, 2013 | RCA Dvd Home Theater System Rtd325w Remote...
Hoooking up surround sounds with optical cable surround system is RT2280 AHHH please help my husband is driving me crazy to get it fixed and he cannot figure it out. Superbowl must be in surround sou
Make sure the digital setting (optical/coaxialor analog)is correct.
If youre connection is differet from default setting
1.select the source
2.press function
3.rotate multi jog to toggle among optical/coaxil/analog to match
yuor connection.
your selection will be stored automatically.
every time you press the source button the input setting(dvd/opti)
will be show on display.
heres a link to the manual go tto page 21 advanced settings.
http://www.google.co.uk/url?sa=t&rct=j&q=surround+sound+RT2280+AHHH&source=web&cd=4&cad=rja&ved=0CEMQFjAD&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_audio%2Fdoc66%2F66651.pdf&ei=G2QMUbKqMOOY0QWJlYBw&usg=AFQjCNG2gc-bExNRynH2JEV22sR-L_ggDg&bvm=bv.41867550,d.d2k
Feb 02, 2013 | RCA RT2280 System
I Have am RCA RT2280 that has no power accept for the led on the power button, Any Ideas?
My RCA 2280 receiver went out on me one day. I thought I'd have to take it to the shop. But before I do that I'll check the fuse because I took it to the shop once before and the repair man said that it was the fuse, he replace it with a new one. So I thought that I would take a look inside first. I took the cover off and looked around and notice that the fuse looked loose. It was loose. I just push it all the way in, replace the cover, plugged it back up and it worked.
As far as the on and off problem goes (which happened to me too) the speaker wire coming from one of the speakers to the back of the receiver were crossed, over loading the system causing it to over heat resulting in it shutting off. I found that the wire was going from red to the gray instead of red to red and gray to gray. Once I rearranged the speaker wires I had no more problems and that was years ago. I haven't had anymore trouble sense. I've had the receiver maybe 12 years now.
Except for today with the Dish Network 20.0 IR 155681 remote control for the 722k HD/DVR. I tried everything in their book but I can't get it to control the RCA 2280 surround sound volume. Anybody gotta clue? I would surely appreciate it. Good Luck.
Dec 14, 2011 | RCA RT2280 System
No sound from tv, dvd, cable. Speaker test does work. Sound stopped suddenly when channel was changed.
What does this mean: "when channel was changed"? TV channel?? Would that mean a remote command was issued? How about FM (no external cabling)?
Page 23...
http://www.retrevo.com/support/RCA-RT2280-Home-Theater-Systems-manual/id/402ag600/t/2/
Sep 02, 2011 | RCA RT2280 System
Comcast on demand custom dvr 3 device codes for sony dvd-hdx576wf
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Aug 06, 2008 | Audio Players & Recorders
Remote Control Code for Insignia NS R5101 Surround Sound Recvr
I have talked with insignia looking for a remote.
Insignia remotes are specialized to their receiver. You cannot connect another remote to the receiver unfortunetly
Jul 18, 2008 | Audio Players & Recorders
Rca rt2770 home theater universal remote code
Apr 05, 2008 | Audio Players & Recorders
Rca rt2280 home theater
hi my son lost my tv remote for my toshiba tv, i was hopping my rca universal remote could adapt to my tv but i do not know the codes how to program it does anywhone have a solution thanks.
Feb 12, 2008 | RCA RT2280 System
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
RCA RT2280 System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
