Question about Epson Stylus C42UX InkJet Printer
Printer cartridges Hi: When I turn on my EPSON Stylus C42UX printer, the cartridges move to the right and then just keep "banging" there - will not stop until I turn it off or disconnect the power source??? HELP!
  • Anonymous Jun 07, 2008
    Wow, thanks! I had the same problem and searched around for a while before I finally found the white plastic part that was sticking up. It was to the far right and I pushed it down with my finger. That solved the problem of the ink cartridge continually banging against the right side. Wonderful!
Hi:
I solved this problem; there was a white plastic "piece" stuck upwards and all I did was push it back down. Now the cartridges are able to go all the way to the right and the printer is working properly. Looks like I need to replace the cartridges now, that's all.
Thanks.
Lori
Posted on Feb 19, 2008
Epson stylus c42ux how do I put in new ink? I can't get to the print cartridges
Power up the printer and open the lid. The print head should come to the center. When you close the lid, it will go back to it's park position. Don't pull it over with the power off.
Jun 01, 2011 | Epson Stylus C42UX InkJet Printer
How do I reset waste ink counter?
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 16, 2010 | Epson Stylus C42UX InkJet Printer
Our printers epson c42ux red light is on stand still
A permanently on red light can mean several things. If the green light is also ON, it means that you heve no paper loaded, an empty or faulty ink cartridge, or a jammed paper feed. I presume you have loaded paper. You say you have changed the ink cartridges. Note that BOTH cartridges must have ink for the printer to work. The simplest way to check this, or to check for a faulty cartridge, is to try another new set of cartridges - compatible cartridges are very cheap on EBay - about £3 a set in the UK.
To check for jammed paper, remove the paper from the sheet feeder and look carefully inside it, and inside the printer (lift the lid) for scraps of jammed paper. Remove any you see. Press the ink/paper feed button and see if it goes through a paper feed cycle. Reinsert the paper and try it again. If it works, turn the printer off and on again, and it should now be OK.
If the green light is OFF, it means you have a Carriage problem, i.e. something is fouling the print head when it tries to go from side to side. Check this with manual movement. Turn the printer off. After a few seconds, turn it back on again. As soon as the print head moves, pull the power cord out of the back of the printer. You should now be able to move the print head across to the left side (gently!) by hand, then move it back to the right and see if it will go fully into its parking bay at the right hand end. You should be able to tell if someting is hindering its movement anywhere.
Please report back with a new comment if none of this solves the problem.
May 31, 2009 | Epson Stylus C42UX InkJet Printer
Epson c42ux cartidge stuck, won't feed
Hi Sunny Shine
It's very difficult to help you if you don't respond to our questions! If you continue to maintain a mysterious silence, we will presume you no longer have a problem - Problem Solved!
Feb 18, 2009 | Epson Stylus C42UX InkJet Printer
Replace ink cartridge
The Reference Manual provides clear instructions on this in the "How to" section. If you don't have a copy, download it from:
http://esupport.epson-europe.com/FileDetails.aspx?lng=en-GB&data=FGQ8MBMpKlt3LcQmNeQVzwoYgQ5dO95G&id=8985
If I can clarify anything, report back
Dec 01, 2008 | Epson Stylus C42UX InkJet Printer
C42UX problem
An unknown printer error has occurred. Turn the printer off, disconnect the interface cable and turn the printer back on. If error disappears, turn the printer off, reconnect the interface cable and turn the printer back on. If error continues then printer needs service. If printer returns to normal the issue is resolved.
Jun 09, 2008 | Epson Stylus C42UX InkJet Printer
EPSON STYLUS C42UX PRINTER.
I have had the same problem, my solution was taking a hammer to the stupid thing and buying a lexmark!
Dec 10, 2007 | Epson Stylus C42UX InkJet Printer
Epson Stylus C42UX InkJet Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
