Question about Kitchen Ranges
Need to locate an EOC for Frigidire gas stove model #plgfmz96ecc. Have power to EOC but nothing on display.
  • 149 Answers
Here you are go here for your part
http://www.repairclinic.com/Appliance-Parts?s=t-plgfmz96ecc.-%3d%3dc212
Posted on Mar 27, 2010
My gas stove beeps and displays F3 what is wrong.it is a kenmore 970-568212
This range was made by Frigidaire for Kenmore. Thus the F3 error could mean a problem with the temperature sensor, the EOC (electronic oven control) or the wiring between the two. You'll need to get to the back of the range and check the resistance at the sensor. In a ~70 degree F environment, the sensor should have a resistance of ~1100 Ohms. (The sensor is connected to the EOC by a pair of violet wires.) Make sure to rule out a problem with the wires, if the resistance tests out of specifications.
If the sensor gives the correct resistance and the wires are fine, replace the EOC. Please check that you have given the full model number, I can't find this model anywhere at Sears Parts Direct or elsewhere.
If the stove is under warranty, contact Sears for repairs. I hope this helps.
Aug 29, 2015 | Kenmore Sears Stove Grate Replacement Gas...
My stove have code f 23 What this mean?
Thanks for your inquiry, Adrian Gonzalez!
From the information you have provided your Electrolux range is displaying an error code of "F23". "F23" stands for communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) I would attempt to perform a reset on your range and you could do that by disconnecting the power from the range for ten minutes. If you continue to experience a problem with the error code it could be an issue with the EOC or VSC (Variable Speed Control) board. Hope this helps. -Matt
Nov 22, 2014 | Electrolux White Gas Slide In Stove Range...
F10 error code on Model # FEFL79GCA Frigidaire Stove
Hello - Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 24, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove oven eoc display is blank
Have you tried to do a hard reset? Find the breaker for the stove and turn it off for a cpl of minutes,, this may correct the problem
Feb 01, 2018 | Frigidaire FGF326AS Gas Kitchen Range
We are geting a F 11 code on this Model number plgfmz96ecc
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11
Shorted Keypad.
1. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
Jun 13, 2011 | Frigidaire PLES399EC Electric Kitchen...
New Electronic Oven Control does not work, Kenmore model 7909634
our top elementes work but the oven and the display don't . All fuses are good and nothing looks burnt. Some smoke came from inside the oven but the elements look good.What's wrong?
Jan 21, 2009 | Kenmore 36665 / 36669 Gas Kitchen Range
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
FRIGIDAIRE STOVE
F1 is a EOC (electronic Oven Control) failure... you will need to repace EOC
Aug 29, 2008 | Frigidaire FEF355 Electric Kitchen Range
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Oven display and oven are not working AT ALL
Most electric range ovens are controlled by the electronic oven control (EOC). If your oven is not working and there is no display on the clock, more than likely you have a bad EOC. The board is not serviceable and has to be replaced. I hope this helps.
Jul 24, 2007 | Whirlpool RF3020 Electric Kitchen Range
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
