Yesterday my webcam was working perfectly and today when I try to access my viewnetcam account, i get a message that says " Failed to connect: try again and access with registered camera host name". My isp is working fine and there have been no changes, but suddenly I can't access my site from my computer, my iphone, or my friend's computer and all of those were working yesterday.
  • 13,433 Answers
Hello
it sounds like to me that the camera is no longer registered properly on your account, try to set it up again, it should work again.
Posted on Jan 31, 2010
Webcam isn't working
It maybe faulty. Try it in another computer. If it still does not then it is faulty. You need a new WEBcam.
Mar 05, 2013 | Logitech C110 Webcam
How do I turn on the integrated webcam?
you either have it disabled in the control panel or the driver files are corrupted. You might have loaded some software which accesses the camera and uninstalled it or its installation failed, taking down the driver wth it. find camera driver and load it. look for it in control panel or device control.
Dec 23, 2012 | HP Computers & Internet
How to configure the UPNP in panasonic camera?If we need access from the internet should we register in viewnet.com?
To access your camera from the Internet you will need to configure uPnP (or configure port forwarding manually) and register with some kind of dns service like viewnetcam (or know your home's external IP address assigned by your Internet Service Provider).
1. To configure uPnP on your camera, look in the network settings for an automatic network configuration option - this will trigger the camera to talk to your router using uPnP to set up port forwarding. The default for one camera is to use port 80 for the outside port and something like 192.168.1.253 for the internal network address (internal to your home only). uPnP will try to configure the second and third cameras to external ports 50000 or 50001. My router failed to configure the 3rd camera so I had to manually add a port forwarding option from my router's admin pages. To note, you can configure all port forwarding manually from within the router admin pages. Just list the internal network address to your camera (like 192.168.2.253) and specify a different port for each camera (like 50000 to 50000). You can then access your camera by typing in 192.168.2.253:5000
2. Then, you should register with viewnetcam.com. Adding your cameras on viewnetcam will give you access to them from outside your house without you having to know the IP address to your home network. You will simply type in your viewnetcam url with ":" and the port number (like username.viewnetcam.com:50000).
Note: When trying to access your camera from outside your home (or even pinging your router from outside your home), you need to know the IP address of your home. This is assigned by your Internet Service Provided and can change every time you reboot your modem. Services like viewnetcam keep track of the IP address to your home and update it automatically when it changes (your camera will communicate with Viewnetcam servers occasionally to update the IP address). All you have to remember is one constant URL (the viewnetcam url) and you can get to your cameras!
Aug 14, 2010 | Panasonic BL-C131 Network Camera
I have successfully setup complete with netcam model BL-111 and BL-131, the system given me internet access is http://koswemin.viewnetcam.com. But I can not log in. The search engine said can't find....
ok i have tried to connect to it . yes its says it cant be found . try recreating the link using a diffrnt name .example > (koswemin1.viewnetcam.com) also make sure that you are spelling everything the same way as when you created the account.. if anything is diffrent it will say can not be found.
Nov 13, 2009 | Panasonic BL-C131 Network Camera
Can't view camera (viewnetcam) with Watchguard X5 router
go into your watchguard control panel and make an exception to the site panasonic use viewnetcam.com then it cant block it.
Feb 26, 2009 | Panasonic BL-C10A Network Camera
Cannot register 2nd BLC30a with viewnetcam.com
RECEIVED THE FOLLOWING INFO FROM A PANASONIC REP IN TORONTO PERTAINING TO SETTING UP A SECOND CAMERA:
"THE FIRST CAMERA MUST NOT BE AT ADDRESS XXXX.XXXX.XXXX.253 (EXAMPLE 192.168.1.253). DO ONE OF THE FOLLOWING BEFORE SETTING UP THE SECOND CAMERA:
1. CHANGE THE IP ADDRESS OF THE FIRST CAMERA THROUGH STATIC SETUP (EXAMPLE 192.168.1.252)
2. DISCONNECT THE FIRST CAMERA FROM THE NETWORK PRIOR TO SETTING UP THE SECOND CAMERA. (THE FIRST CAMERA WILL GRAB A NEW ADDRESS THROUGH DHCP THE NEXT TIME IT IS CONNECTED).
THE REASON FOR DOING ONE OF THE ABOVE IS THAT THE FIRST CAMERA IS PROBABLY STILL AT AN IP ADDRESS ENDING IN 253. A NEW OR FACTORY RESET CAMERA WILL WANT TO GRAB THE SAME ADDRESS AND CAUSE AN IP CONFLICT ON YOUR NETWORK.
HOPE THIS HELPS YOU.
WARMDF
Feb 09, 2008 | Panasonic BL-C30A Network Camera
Problems in connecting to my blc30a through the website viewnetcam.com
Are you trying to access the camera in the local network? Have you assigned a static ip address to the camera? Which router are we using?
Feb 27, 2007 | Panasonic BL-C30A Network Camera
Computers & Internet Logo
David Payne
David Payne
